Function not being run
This has had me stumped for a couple of hours. The function CUBEPowerUp(), which works in other sketches, (including those running it in Setup, like this one) is not being run. I do get the message indicating that Setup has finished.
Note: while trouble-shooting, I've eliminated the main loop to avoid the sketch running it.
For comparison I've also shown the code of a similar sketch that works fine.
// Friday 13 November 2020, 1746. NOT POWERING UP
// Using pin 10 (green LED) to indicate D6 trigger tasks in progress
// Pin 4 input sets video duration (H = 30s, L = 5s))
// Pin 6 input LOW triggers loop
// Pin 8 HIGH = CUBE video recording
// Pin 9 is CUBE servo control
// Pin 10 is greenledPin
#include <VarSpeedServo.h> // Uses the VarSpeedServo library
// Create servo object
VarSpeedServo myCUBEservo;
const byte outPosCUBE = 35; // Trial & error; needs regular re-checking
const byte inPosCUBE = 15; // Ditto
const byte triggerPin = 6;
const byte redledPin = 8;
const byte greenledPin = 10; // (Green LED on bb)
const byte switchPin = 4;
int videoLength; // Declared here, then set in Setup
// From 'Basic-goTime' sketch
int nextTime = 20000;  // Do this every 20s
long int goTime;
  // Power up CUBE
  CUBEPowerUp();
  delay(2500);
  Serial.println("CUBE powered up and recovery delay ended");
  Serial.println("");
  Serial.println("CUBE-VideosPhotosKA-13Nov20");
  pinMode(switchPin, INPUT_PULLUP);
  pinMode(triggerPin, INPUT_PULLUP);
  pinMode(redledPin, OUTPUT);
  pinMode(greenledPin, OUTPUT);
  // Initialise the CUBE servo
  myCUBEservo.write(outPosCUBE); // Initial arm pos'n
  myCUBEservo.attach(9); // White wires
  Serial.println("CUBE servo attached");
  // Test D4 to choose value of videolength
  if (digitalRead(switchPin) == HIGH)
    videoLength = 30000;
    videoLength = 8000;
  Serial.print("Video length = ");
  Serial.println(videoLength);
  Serial.print("outPosCUBE/inPosCUBE = ");
  Serial.print(outPosCUBE);
  Serial.print("/");
  Serial.println(inPosCUBE);
  Serial.println("Setup finished; waiting for low D6");
  Serial.println("--------------------------------------------");
  goTime = millis(); // Start time
// Had to include this to avoid error about undefined reference to 'loop'
void loop() {}
void CUBEPowerUp()
  // Power up CUBE with long press > 3 s
  myCUBEservo.write(inPosCUBE);
  delay(3500); // Press for > 3s to toggle power
  delay(200);
void CUBESingleButtonPress()
  // Start or Stop video with single button press
  delay(200);
  delay(200);
void functionGo()
  // Take a photo with CUBE: single press
  CUBESingleButtonPress();
  goTime = millis() + nextTime; // When to do it again
But the following works OK:
// Friday 13 November 2020, 15:13, house;
  Serial.println("");
  Serial.println("CUBE-Videos-13Nov20");
    videoLength = 8000;
  Serial.print("/");
  // Run only when a LOW on D6 is detected
  if (digitalRead(triggerPin) == LOW)
    Serial.println("Triggered by D6; TASKS STARTED");
    // TASK #1: Take greenledPin (D10) high, to indicate D6 trigger has occurred
    digitalWrite(greenledPin , HIGH);
    // TASK #2: Power up CUBE
    CUBEPowerUp();
    // Seems to then need a long delay - for battery recovery?
    delay(2500); // 1500 & 2500 worked; 500 & 1000 failed
    // TASK #3: Start CUBE video with two presses
    delay(10);
    // TASK #4: Start video with two presses
    Serial.println("Started CUBE video");
    digitalWrite(redledPin , HIGH) ;
    // TASK #5: Delay for recording videos
    delay(videoLength); // ACTUAL individual durations will be different
    // TASK #6: Stop CUBE video with single press
    digitalWrite(redledPin , LOW) ;
    Serial.println("CUBE video ended");
    // TASK #7: Power down CUBE
    delay(2000);
    CUBEPowerDown();
    // TASK #8: Take greenledPin (D10) low, to indicate triggered task finished
    digitalWrite(greenledPin , LOW);
    delay(2000); // Brief pause while CUBE powering down, may be redundant
// Servo functions here; take care when updating
void CUBEPowerUp()
  delay(200);
void CUBEPowerDown()
  // Power down CUBE with long press > 3 s
  delay(3500); // Press for > 3s to power down
  // CUBE gives a final longish beep before switching off
  Serial.println("Cube powered down; TASKS ENDED");
  Serial.println(" "); // Blank line
  // Stop video with single button press
  delay(200);
  delay(200);
In setup(), shouldn't
go before you call CUBEPowerUp()?
Blackfin:
Yes, thank you so much, that fixed it!
