Function Overloading
The following code below defines a fn() which is overloaded. One with no parameters, one with char*, and one with an int parameter. Compiling the code renders an error on line 14 “ call of overloaded 'fn()' is ambiguous”. Commenting line 14 produces a successful compile. Any ideas on what is wrong?
=========== C O D E ===========
1 void fn() {
2 Serial.println("no parameters");
3 }
4 void fn( char* msg = " " ) {
5 Serial.println( "char *" );
6 }
7 void fn( int n = 0 ) {
8 Serial.println( "int" );
9 }
10
11 void setup() {
12 fn("hello");
13 fn(199);
14 fn(): // correction fn();
15 }
16
17 void loop() {
18 }
========== C O M P I L E =========
sketch_oct06a.ino:1:6: note: candidate: void fn()
void fn() {
sketch_oct06a.ino:4:6: note: candidate: void fn(char*)
sketch_oct06a\sketch_oct06a.ino:7:6: note: candidate: void fn(int)
exit status 1
Is that a colon at the end of line 14??
Yes it is! Good catch, ... but still fails with a “;”!
You can't have a no argument and also have a default parameter for the other ones. Which one should the compiler call? Should it call the no argument, or one of the others using the default argument? That's ambiguous just like it said.
That was it. Took out default values and it worked.
Thanks a bunch!
