Function pointers between classes
I have 2 classes: MainClass and SubClass
SubClass contains a lot of variables and methods to alter the variables. When I alter a variable in SubClass I want it to call a function in MainClass to tell it the new value of the variable. This is so MainClass can do things with that new value.
The code I have at the moment is as follows:
MainClass.h
#include SubClass.h
class MainClass
public:
    MainClass();
    ~MainClass();
    void SubValueChanged(byte new_value);
private:
    SubClass* sub_;
MainClass.cpp
#include MainClass.h
MainClass::MainClass()
    sub_= new SubClass(SubValueChanged);
MainClass::~MainClass()
MainClass::SubValueChanged(byte new_value)
// do something here with new_value
SubClass.h
typedef void (ByteFuncPtr*)(byte);
class SubClass
public:
    SubClass(void (*val_func)(byte));
       ~SubClass();
        ChangeValue(byte new_val);
private:
        static ByteFuncPtr val_ptr_;
        byte value;
SubClass.cpp
#include SubClass.h
SubClass::SubClass(void (*val_func)(byte))
    val_ptr_ = val_func;
SubClass::~SubClass()
SubClass:ChangeValue(byte new_val)
     value = new_val;
     val_ptr_(new_val);
Now I'm aware what I'm doing wrong - When I declare sub_ in MainClass::MainClass(), I need to send MainClass (i.e. this) as well as the function I want to call (SubValueChanged).
The issue is that I'm not sure what the syntax is for doing this. i.e. how do I pass this to SubClass?
If I pass it MainClass this, then I have to include MainClass.h in SubClass.h, which isn't a good idea.
I'm guessing what I'm trying to do is quite a common C++/C task and I'm just trying to find the best way of doing it. :)
cheers Paul
Look at this, it might help you.
http://www.cplusplus.com/doc/tutorial/inheritance/
The first thing that you are doing wrong involves terminology. SubClass is in no way related to MainClass. So, calling it a sub-class is wrong.
No, you don't. You can put
class MainClass;
in SubClass.h, before the definition of the class mis-named SubClass.
In SubClass.cpp, you will need to include MainClass.h.
Hmm, fair point about the poor naming. ClassA and ClassB would have been more appropriate.
Think I get it now, thanks. This tutorial helped explain further too: http://www.newty.de/fpt/callback.html
