Function pointers passed to other functions
Okay, can't figure out what I'm doing wrong here but here's my code. When I try to compile it claims ModuleSet is not in the global scope, which it is. If I remove the function pointer part of the declaration it compiles fine.
// function is called inside another function higher up in the code
void calling_function()
      ModuleSet("Loud", &LOUD_buzzer_use, &LOUD_buzzer_delay, &LOUD_buzzer_duration, &Sound_Buzzer);
// function declared down below like this
void ModuleSet( char* Title, byte *useThisModule, byte *delayThisModule, byte *durationThisModule, void (*testRunPtr)())
  // actions
void Sound_Buzzer()
  // buzzing
Any ideas?
If I'm right you should declare a function before calling it. So Module_Set should be declare before using it in calling_function.
Or you can declare your functions in a header file included at the very beginning of your code.
I would think the same, however if I remove the function pointer part everything works fine. It has only become a problem now that I've tried to use a function pointer.
Do the function types match?
Maybe try:
void (*testRunPtr)(void))
I think the problem is caused by the way arduino does its automatic prototyping on .pde files. If you define the function pointers in a separate .h file and include this it should work:
 // test.h
typedef void (*testRunPtr )(void);
// sketch file
void ModuleSet( char* Title, byte *useThisModule, byte *delayThisModule, byte *durationThisModule, testRunPtr )
  // actions
void Sound_Buzzer()
  // buzzing
I think this:
Should be this:
ModuleSet("Loud", &LOUD_buzzer_use, &LOUD_buzzer_delay, &LOUD_buzzer_duration, Sound_Buzzer);
