Function Problem. (Void Loop)
I have tried in different ways this code but i cant run two different functions within the void loop .
one of the code block is for IMU, servos and other one for pot and servos. When running this code GYRO and servos is working well but i cant control servos by pot.
Sorry for bad language.
Best Regards.
void loop(){
  servoVal = analogRead(pot1);
  servoVal = map(servoVal, 0, 1023, 0, 179);
  pservo.write(servoVal);
  delay(15);
  servoVal = analogRead(pot2);
  dservo.write(servoVal);
  delay(15);
  servoVal = analogRead(pot3);
  oservo.write(servoVal);
  delay(15);
  servoVal = analogRead(pot4);
  eservo.write(servoVal);
  delay(15);
  /* Update all the values */
  uint8_t* data = i2cRead(0x3B,14);
  accX = ((data[0] << 8) | data[1]);
  accY = ((data[2] << 8) | data[3]);
  accZ = ((data[4] << 8) | data[5]);
  tempRaw = ((data[6] << 8) | data[7]);
  gyroX = ((data[8] << 8) | data[9]);
  gyroY = ((data[10] << 8) | data[11]);
  gyroZ = ((data[12] << 8) | data[13]);
  /* Calculate the angls based on the different sensors and algorithm */
  accYangle = (atan2(accX,accZ)+PI)*RAD_TO_DEG;
  accXangle = (atan2(accY,accZ)+PI)*RAD_TO_DEG;
  double gyroXrate = (double)gyroX/131.0;
  double gyroYrate = -((double)gyroY/131.0);
  //gyroX
  gyroXangle += gyroXrate*((double)(micros()-timer)/1000000); // Calculate gyro angle without any filter
  gyroYangle += gyroYrate*((double)(micros()-timer)/1000000);
  gyroXangle += kalmanX.getRate()*((double)(micros()-timer)/1000000); // Calculate gyro angle using the unbiased rate
  compAngleX = (0.93*(compAngleX+(gyroXrate*(double)(micros()-timer)/1000000)))+(0.07*accXangle); // Calculate the angle using a Complimentary filter
  gyroYangle += kalmanY.getRate()*((double)(micros()-timer)/1000000);
  compAngleY = (0.93*(compAngleY+(gyroYrate*(double)(micros()-timer)/1000000)))+(0.07*accYangle);
  kalAngleX = kalmanX.getAngle(accXangle, gyroXrate, (double)(micros()-timer)/1000000); // Calculate the angle using a Kalman filter
  mapX = map(kalAngleX, 0, 200, 0, 179);     //calculate limitation of servo mechanical
  kalAngleY = kalmanY.getAngle(accYangle, gyroYrate, (double)(micros()-timer)/1000000);
  mapY = map(kalAngleY, 0, 200, 0, 179);
  timer = micros();
  //gyroY
  correctionX = 27;     // EDIT THIS VALUE FOR SERVO CORRECTION ANGLE
  correctionY = 27;     // EDIT THIS VALUE FOR SERVO CORRECTION ANGLE
  moveX = 270 - (kalAngleX) + correctionX;
  moveY = 270 - (kalAngleY) + correctionY;
  // ------- SEND TO SERVO START ----- /
  xservo.write(moveX);   // Send signal to servo
  delay(15);     // delay to allow servos to move (ms)
  yservo.write(moveY);   // Send signal to servo
  // ------- SEND TO SERVO END ----- /
  delay(1); // The accelerometer's maximum samples rate is 1kHz
// -- FUNCTIONS START --
void i2cWrite(uint8_t registerAddress, uint8_t data){
  Wire.beginTransmission(IMUAddress);
  Wire.write(registerAddress);
  Wire.write(data);
  Wire.endTransmission();                       // Send stop
uint8_t* i2cRead(uint8_t registerAddress, uint8_t nbytes) {
  uint8_t data[nbytes];
  Wire.endTransmission(false); // Don't release the bus
  Wire.requestFrom(IMUAddress, nbytes);   // Send a repeated start and then release the bus after reading
  for(uint8_t i = 0; i < nbytes; i++)
    data[i] = Wire.read();
  return data;
That is 4 servos being controlled by 4 potentiometer. What is wrong with it ?
You can use a single delay(15); You could write the value of the potentiometer to the Serial monitor.
when i upload this code, pots and servos code block is not working. there is work only servos by gyro. i cant control all of servos. can i write different kind of function for 4 servos and 4 pots in void loop? i tried tons of different method but i cant.
All of this code.
#include <Servo.h>
const int pot1 = 0;
const int pot2 = 1;
const int pot3 = 2;
const int pot4 = 3;
int servoVal;
Servo xservo;
Servo yservo;
Servo pservo;
Servo dservo;
Servo oservo;
Servo eservo;
#include <Wire.h>
#include "Kalman.h"
Kalman kalmanX;
Kalman kalmanY;
uint8_t IMUAddress = 0x68; // MPU6050 Address
/* IMU Data */
int16_t accX;
int16_t accY;
int16_t accZ;
int16_t tempRaw;
int16_t gyroX;
int16_t gyroY;
int16_t gyroZ;
int moveX;
int mapX;
int correctionX;
int moveY;
int mapY;
int correctionY;
double accXangle;
double accYangle;
double gyroXangle = 9;
double gyroYangle = 9;
double compAngleX = 90;
double compAngleY = 90;
double kalAngleX;
double kalAngleY;
uint32_t timer;
  xservo.attach(13);
  yservo.attach(12);
  pservo.attach(11);
  dservo.attach(10);
  oservo.attach(9);
  eservo.attach(8);
  Wire.begin();
  i2cWrite(0x6B,0x00);           // Disable sleep mode
  if(i2cRead(0x75,1)[0] != 0x68) {   // Read "WHO_AM_I" register
    while(1);
  kalmanX.setAngle(90);  // Set starting angle
  kalmanY.setAngle(90);
  timer = micros();
  //gyroX
  timer = micros();
  //gyroY
  delay(15);
  delay(15);
  delay(15);
  delay(15);
  Wire.write(data);
  return data;
What do you Serial debug statements tell you is happening? Why don't you have any? It's pretty dumb to debug in the dark. Turn the damned lights on.
Make a test-sketch with only the potentiometers. Add Serial.begin() and Serial.print() function to print the values as PaulS wrote.
The i2cRead function creates a buffer on the stack, and returns a pointer to that buffer. I have seen that before, but I would never do that. After the function has returned, the values on the stack are no longer valid.
