I am trying to make a function getIP which when called returns an IP address
caller:
IPAddress anIP = getIP();
callee
IPAddress getP(){
IPAddress ip (1,2,3,4);
return ip;
What am I doing wrong?
Thanks for your help!
caller:
callee
IPAddress getP(){
return ip;
Not posting a complete program
I can make no sense of the snippets that you posted
What's the error?
How is IPAddress defined?
I now realize the importance of posting the problematic code by itself! My appologies
Here is the code ... and it works perfectly well!
#define sp Serial.print
#define spln Serial.println
#include <SPI.h>
#include <Ethernet.h>
Serial.begin(38400);
IPAddress myIP=getIP();
sp("returned ip is ");spln(myIP);
void loop(){;}
IPAddress getIP(){
byte byteArray[4]={0,1,2,3};
IPAddress ip (byteArray[0], byteArray[1], byteArray[2], byteArray[3]);
sp("ip in callee is "); spln(ip);
return ip;
guy_c:
I now realize the importance of posting the problematic code by itself! My appologiesHere is the code ... and it works perfectly well!
#include <SPI.h>
void loop(){;}
IPAddress getIP(){
return ip;
you code will work until it doesn't.
the object "ip" becomes undefined once you exist the function.
arduino_new:
you code will work until it doesn't.the object "ip" becomes undefined once you exist the function.
But the value is returned by the function.
arduino_new:
Thanks. Must I understand that it worked by chance and that it may -depending upon the execution time? stop working?
Can you recommend a more robust implementation of this function?
guy_c:
I think that @arduino_new is confused - if you had returned a pointer to "ip", then you would have had a problem, because the pointer would be to a variable on the stack that could be overwritten at any time after the return from the function.
But you're returning the variable itself, so that's OK.
Thanks TolpuddleSartre, Maybe you'll want to comment on the 'public IP updater' just posted here
TolpuddleSartre:
I think that @arduino_new is confused - if you had returned a pointer to "ip", then you would have had a problem, because the pointer would be to a variable on the stack that could be overwritten at any time after the return from the function.But you're returning the variable itself, so that's OK.
I think you have it flipped. it is OK if it is dynamically allocated.
arduino_new:
Huh?
TolpuddleSartre:
Huh?
Isn't "ip" a reference to an IPAdress object which was created inside the function?
No, see this
"getIP()" makes no sense, since it would only make sense to call it once, thus it is not needed. In order to do what you want, you should pass the instance of "IPAddress" as an argument to "getIP" or return the numeric value representing the IP:
//As argument
void getIP1(IPAddress &ipa)
ipa = IPAddress(byteArray[0], byteArray[1], byteArray[2], byteArray[3]);
sp("ip in callee is "); spln(ipa);
//Numeric value
uint32_t getIP2(){
byte byteArray[4]={4,5,6,7};
return ip;
IPAddress myIP;
getIP1(myIP);
myIP = getIP2();
Just in case some official, long-established, real-world examples of returning an IPAddress from a function are needed:
