Function returning PROGMEM stirngs
What is the correct way of returning a pointer to a PROGMEM string?
For example the code
const char str[] PROGMEM = "Hello World!";
const char * getStr() {
  return str;
  char msg[32];
  sprintf(msg, "%s", getStr()); // <--- This will print strange characters in msg
  Serial.println(msg);
Will procduce strange characters in serial monitor. (Yes, I double checked baud)
But substituting the function call inside sprintf with 'str' (which is the data actually returned), everything works.
From the PROGMEM doc
const char signMessage[] PROGMEM  = {"I AM PREDATOR,  UNSEEN COMBATANT. CREATED BY THE UNITED STATES DEPART"};
int len = strlen_P(signMessage);
  for (k = 0; k < len; k++)
    myChar =  pgm_read_byte_near(signMessage + k);
    Serial.print(myChar);
Or further in the doc
#include <avr/pgmspace.h>
const char string_0[] PROGMEM = "String 0";   // "String 0" etc are strings to store - change to suit.
const char string_1[] PROGMEM = "String 1";
const char string_2[] PROGMEM = "String 2";
const char string_3[] PROGMEM = "String 3";
const char string_4[] PROGMEM = "String 4";
const char string_5[] PROGMEM = "String 5";
// Then set up a table to refer to your strings.
const char* const string_table[] PROGMEM = {string_0, string_1, string_2, string_3, string_4, string_5};
char buffer[30];    // make sure this is large enough for the largest string it must hold
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[i]))); // Necessary casts and dereferencing, just copy.
Should give you ideas
