Hi
I want code to change the frame rate(frequency) of laser sensor tfmini-s to be
more than 100
For Arduino uno
Is this a commercial order? Are you ready to pay for code?
Why don't you just go ahead and do it?
No i only want to know the function that can change the value of Frame rate
I already have code that operate tfmini-s
But i only want to know the function that can change the value of Frame rate
Every now and then it is extremely useful to have a look at the libary used for this purpose.
Are you using any library to work with tfmini-s ?
Yes i use library
TFMini.h
And
I used function
(SetCommand(SET_FRAME_RATE,FRAME_300
But it didn't work
I use library
TFMini.h
So i just want to know the function that change frequency
I used function
SetCommand(SET_FRAME_RATE,FRAME_300)
and it didn't defined IN that library
Where did you get this command from? There is no such command in the library.
This library doesn't contain a function to change the frame rate. If you need it - you should write it yourself. The command syntax can be found in the Manual:
This is the code
include <SoftwareSerial.h>
#include "TFMini.h"
TFMini tfmini;
SoftwareSerial SerialTFMini(2, 3); //The only value that matters here is the first one, 2, Rx
void getTFminiData(int* distance, int* strength)
static char i = 0;
char j = 0;
int checksum = 0;
static int rx[9];
if (SerialTFMini.available())
rx[i] = SerialTFMini.read();
if (rx[0] != 0x59)
i = 0;
else if (i == 1 && rx[1] != 0x59)
i = 0;
else if (i == 8)
for (j = 0; j < 8; j++)
checksum += rx[j];
if (rx[8] == (checksum % 256))
*distance = rx[2] + rx[3] * 256;
*strength = rx[4] + rx[5] * 256;
i = 0;
i++;
Serial.begin(115200); //Initialize hardware serial port (serial debug port)
while (!Serial); // wait for serial port to connect. Needed for native USB port only
Serial.println ("Initializing...");
SerialTFMini.begin(TFMINI_BAUDRATE); //Initialize the data rate for the SoftwareSerial port
tfmini.begin(&SerialTFMini); //Initialize the TF Mini sensor
int distance = 0;
int strength = 0;
getTFminiData(&distance, &strength);
while (!distance)
if (distance)
Serial.print(distance);
Serial.print("cm\t");
Serial.print("strength: ");
Serial.println(strength);
delay(100);
Can u give me hint to how can i write this function cause the manual use hexadecimal statements and i don't understand it
