function to restart looping?
hay… there is function to restart looping
example…
int val = analogRead(1);
digitalWrite(led, HIGH);
delay(1000)
digitalWrite(led, LOW);
delay(1000)
digitalWrite(led2, HIGH);
delay(1000)
digitalWrite(led2, LOW);
if (val == 5)               <============= if val = 5 restart looping from begining
{   restart looping from begining      }
delay(1000)
digitalWrite(led3, HIGH);
delay(1000)
digitalWrite(led3, LOW);
delay(1000)
there is function to do it?
It is ugly and not recommended but you could use a goto statement. Always better to restructure your code so that the condition that causes the looping is in the loop statement, if that makes sense.
return;
Couldn’t you just say
if(val !=5){
// all the other stuff
ase123:
Is a bad idea. The hardware has not been initialized at the point analogRead is called. Move the initialization to setup where it belongs.
	int loopVal;
	while (1){
		loopVal=1;
		while (analogRead(1)!= 5) {
			switch(loopVal)	{
				case 1:
					loopVal++;
				case 2:
					loopVal++;
				case 3:
					loopVal++;
				case 4:
					loopVal++;
				case 5:
					loopVal++;
				case 6:
					loopVal=1;
@Arrch
yeah the function return; is work..
thanks for all
inner loop can be shortened by using bitmasks.
    while (analogRead(1) != 5) {
			switch(loopVal)	{
				case 1:
					loopVal++;
				case 2:
					loopVal++;
				case 3:
					loopVal++;
				case 4:
					loopVal++;
				case 5:
					loopVal++;
				case 6:
					loopVal=1;
  if (loopVal & 0x01) digitalWrite(led, HIGH);
  else digitalWrite(led, LOW);
  loopVal++;
  if (loopVal == 6 ) loopVal=1;
Am I the only one who thinks this is a really bad idea?
yeah 5 is such a magic number, one should use a #define for that :wink:
#define MAGICNUMBER 5
(analogRead(1) != MAGICNUMBER )
but then, it might be just what the OP intended ...
No, not the magicness, just the precision, from an analogue input.
