Function was not declared in this scope - compile error
/*-----( Import needed libraries )-----*/
#include <Wire.h>
/*-----( Declare Constants )-----*/
/*-----( Declare objects )-----*/
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27
/*-----( Declare Variables )-----*/
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x00, 0xCD, 0x4E
}; //physical mac address
byte ip[] = {
  192, 168, 1, 139
}; // ip in lan
byte gateway[] = {
  192, 168, 1, 1
}; // internet access via router
// byte subnet[] = {255, 255, 255, 0 }; //subnet mask
IPAddress dns(204,117,214,110); // OpenDNS IP
EthernetServer server(90); //server port
// DECLARE
String readString;
#define TSTAT 12
#define FAN 13
#define TEMP 0
#define PUMP 11
#define LITE 10
const long ONE_SECOND = 1000;		  //DEFINE ONE SECOND
const long ONE_MINUTE = 60 * ONE_SECOND;   //DEFINE ONE MINUTE
const long ONE_HOUR = 60 * ONE_MINUTE;     //DEFINE ONE HOUR
int T = 0;					   //ANALOG READ TEMP
int temp = 0;					//ACTUAL TEMP
int tstat = LOW;				   //THERMOSTAT STATE VARIABLE
  // START  Ethernet
  //Ethernet.begin(mac, ip, gateway, subnet);
  Ethernet.begin(mac, ip, gateway,dns);
  server.begin();
  pinMode(TSTAT, INPUT);
  pinMode(FAN, OUTPUT);
  pinMode(TEMP, INPUT);
  pinMode(PUMP, OUTPUT);
  pinMode(LITE, OUTPUT);
  pinMode(8, OUTPUT); //pin selected to control
  pinMode(9, OUTPUT); //pin selected to control FAN
  //enable serial data print  FOR TESTING ON Serial monitor
  // Create a client connection
  // If someone connects to the server...
  if (client)
    // Create a variable to hold whether or not we have received a blank
    // line from the web browser
    boolean current_line_is_blank = true; //new
    while (client.connected())
      lcd.clear();
      lcd.print("CONNECTED!");
      lcd.blink();
      // If the client has sent us some data...
      if (client.available())
        // Keep the last letter of whatever they sent us
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100)
          //store characters to string
          readString += c;
          //Serial.print(c);
          digitalWrite(4, HIGH); // turn on "connected" LED
          // If we've gotten to the end of the line (received a newline
          // character) and the line is blank, the http request has ended,
          // so we can send a reply
          if (c == '\n' && current_line_is_blank)
            client.println("HTTP/1.1 200 OK"); //send new page
            client.println(F("Content-Type: text/html"));
            client.println();
            client.println();
            client.print(F("<body style=background-color:BLACK>")); //set background to BLACK
            client.println(F("<META HTTP-EQUIV=REFRESH CONTENT=35 URL=>"));
            // client.println(F("<META HTTP-EQUIV=REFRESH CONTENT=5; url=>"));
            client.println(F("<HTML>"));
            client.print(F("<HEAD>"));
            client.println(F("<center>"));
            client.println(F("<font color=’green’><h1>INTERNET -- CONTROL </font></h1>/"));//send first heading
            client.println(F("<hr />"));
            client.println(F("<font color=’#0D8112’ size=’5?> "));
            client.println(F("</center>"));
            //if HTTP request has ended
              Serial.println(readString); //print to serial monitor for debugging
                if(readString.indexOf("off8") >0)//checks for off  reading string from Ethernet web form button
                digitalWrite(8, LOW);    // set pin 8 low
                digitalWrite(9, LOW); //FAN
                Serial.println("Led 8 Off"); // blue led
              if(readString.indexOf("sen11") >0)//checks for sensor loop test
                heat();// goto heat function
              // radiobuttons
              client.print(F("<form method=get name=LED>"));
              client.println(F("<button name=sen11 value=1 type=submit style=font-weight:bold;color:red;height:50px;       width:60px>sen</button>"));
              client.println("</center>");
              client.println("</form>"); // new
              client.println(F("<hr />"));  // print a header on webpage ---------------------
            client.println("<center>");
            client.println(F("</body></html>"));
            //stopping client
            client.stop();
            digitalWrite(4, LOW); // turn OFF "connected" LED
            delay(2000);
            readString="";
            // THIS IS A TEST FUNCTION  //
            void heat()
              temp = analogRead(TEMP);		 //READ TEMP
              Serial.println(temp);		    //PRINT TEMP FOR DIAG
              delay(250);				  //WAIT 1/4 SECOND
              tstat = digitalRead(TSTAT);	    //READ THERMOSTAT STATE
              if (tstat == HIGH)			 // IF THERMOSTAT CALLS FOR HEAT
                digitalWrite(FAN, HIGH);	     //TURN FAN ON
              else					   //IF THERMOSTAT DOESNT CALL FOR HEAT
                digitalWrite(FAN, LOW);		//TURN FAN OFF
                digitalWrite(PUMP, LOW);
                return;
              if  (temp > 475)
                coilWarmup;
I am attempting to learn how incorporate a function into my code.
The Ethernet part all works fine and the button displays the correct code when clicked in the web page
I setup a web button  which sends a sen11 code and if so then it should jump to the heat function
The Ethernet part all works fine.
I cant seem to get the code to jump/go to my void [u]heat function[/u]
[u]Compile error  - heat was not declared in this scope[/u]
How do i get rid of this...  ?
Thanks
Joe
Lots of details missing. What version of the IDE are you using? What errors are you getting?
void heat()
Embedded in loop. Your crappy indentation isn't helping. Use Tools + Auto format to straighten that mess up.
There is a { missing here for a start:
void heat()
I had to add about 5 x } here just to get the auto-format to work.
          delay(2000);
          readString="";
These braces are supposed to match you know. They aren't just there for decoration.
Thanks,
I knew i lost the { somewhere but could not match them up..
Joe
Is there an easy method / logic on how to keep track or determine when and where open { and } are placed?
Joe
First, do the auto-format in the IDE, and then the braces should more-or-less line up vertically.
Second, if you put the cursor after one, the other (corresponding) one should be highlighted slightly.
joeman: Is there an easy method / logic on how to keep track or determine when and where open { and } are placed?
Joe
When you place an opening brace, immediately place the closing brace. Remember, they should vertically line up.
Ah.. You declared your heat function -inside- your loop function. Maybe things have changed, but in my day I never saw stuff like that. Try moving your heat function up above your start function? Then call it from your loop function when you want it.
-jim lee
