Hi, i am using some functions that use an array as a parameter, but I want to give that array to a function inside the function. Will it work if I do it like in the code below(functions stuurLed, verwijderLed and stuurNaarChip) because if I use the "[]" behind the name it won't compilate.
* Simple test of ht16k33 library turning on and off LEDs
#include <Wire.h>
// Define the class
byte adres = 0x70;
byte displayRam[16] = {
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000
Serial.begin(57600);
Serial.println(F("ht16k33 light test v0.01"));
Wire.begin();
Wire.beginTransmission(adres);
Wire.write(0b00100001);
Wire.endTransmission();
Wire.write(0b10000001);
Wire.write(0b10100000);
Wire.write(0b11101111);
void stuurLed(int rij, int kolom, byte ram[]){
bitSet(ram[kolom],rij);
stuurNaarChip(ram);
void verwijderLed(int rij, int kolom,byte ram[]){
bitClear(ram[kolom],rij);
stuurNaarChip(ram);
void stuurNaarChip(byte ram[]){
Wire.write(0b00000000);
for (int i=0; i<(sizeof(ram)-1);i++){
Wire.write(ram[i]);
stuurNaarChip(displayRam);
delay(5000);
stuurLed(0,0,displayRam);
delay(5000);
verwijderLed(0,0,displayRam);
delay(5000);
} // loop
