function with optional arguments
Hey there,
I've been working on a button funktion to make inputs easier.
I want to have some optional configuration values, to get funktion calls smaller.
I found an example to do so in the forum archive to do so:
funktionType (dataType var, dataType var = defaultValue){
funktion
When I tried this arduino did not recognise the function any more. The error message was: "[functionName] was not declared in this scope.
The author of the original post said it worked for him, but I am really confused about the error message.
Can someone help me out?
Thank you
javamaster10000
Your example confuses me. For example, it uses 'var' twice. I also don't know what you mean by:
Please use code tags to copy and paste the actual code and the actual error messages.
Thanks!
javamaster10000:
Only the text gets shorter, the function will be called with the inserted default(s).
void withDefault(int aNumber = 10) {
void someFunction() {
  withDefault();
  withDefault(10);
Uncompiled and untested example.
This compiled without error for me:
void setup() {}
void loop(){
  withDefault();
  withDefault(10);
Seems like you have it figured out.
