function with temperature sensor malfunctions
Hi guys
first of all here is the code:
int temperatureMeasure(byte sensorPinLocal, int timerLocal) {
readValue = analogRead(sensorPinLocal); voltage = readValue * 5 / 1024; temperature = (voltage - 500) / 10;
Serial.print( "The voltage is " + String(voltage, 2) + ", this value is a temperature of " + String(temperature, 1) + ".");
return temperatuur;
delay(timerLocal); }
If I open my serial monitor to take a look at the values, my voltage is 0.00 and my temperature -50.0. I can't seem to find my mistake, any help?
my voltage and temperature are floats.
But the values used in computing them are all ints.
voltage = readValue * 5.0 / 1024.0;
This:
  return temperatuur;
Indicates that your code is unlikely to compile, or has a bug in it.
It would be interesting to know what readValue is, no?
it works, thank you Paul.
readValue is an integer I use for my value that comes in the analog input.
  return temperatuur;
That delay will never be executed.
Rossouw: it works, thank you Paul.
Indeed. Finding out what value it holds might be useful information to debug with.
