I assume you use this sketch (from Wokwi https://wokwi.com/projects/371869704522593281 )
#include <list>
#include <SD.h>
#define CS_PIN 5
File root;
std::list<String> indexList;
std::list<String> outList;
Serial.print("Initializing SD card... ");
if (!SD.begin(CS_PIN)) {
Serial.println("Card initialization failed!");
while (true);
Serial.println("initialization done.\n");
createIndexList("FileB.txt");
evaluateFile("FileA.txt");
writeResultToFile("FileC.txt");
delay(100);
// nothing happens after setup finishes.
void createIndexList(String aFile){
indexList.clear();
String aLine = "";
File textFile = SD.open("/"+aFile);
if (textFile) {
Serial.println("Creating Index List from "+aFile);
while (textFile.available()) {
char c = textFile.read();
if (c >= ' ') {
aLine = aLine + c;
if (c == 10){
checkForIndexList(aLine);
aLine = "";
textFile.close();
if (aLine != "") {
Serial.println("error opening "+aFile);
showList();
void checkForIndexList(String line){
String idx = stripIndex(line);
if (idx > "") {
indexList.push_back(idx);
String stripIndex(String Line){
int c1 = Line.indexOf(',');
int c2 = Line.indexOf(',', c1+1);
String index = "";
if (c1 >= 0 && c2 > c1){
index = Line.substring(c1+1, c2);
return index;
void showList(){
Serial.println("===== Index List ========");
for (auto idx : indexList){
Serial.println(idx);
Serial.println("=========================\n");
void evaluateFile(String aFile){
String aLine = "";
outList.clear();
if (textFile) {
Serial.println("Evaluating "+aFile);
Serial.println("\n======= New Entries ========");
if (c >= ' ') {
aLine = aLine + c;
if (c == 10){
checkForOutList(aLine);
aLine = "";
textFile.close();
Serial.println("============================\n");
void checkForOutList(String line){
if (idx > "") {
if (!indexFound(idx)) {
outList.push_back(line);
void checkIndex(String line){
if (idx > "") {
boolean indexFound(String aIndex){
boolean found = false;
for (auto ix : indexList){
if (aIndex == ix) found = true;
return found;
void writeResultToFile(String wFile){
File tFile = SD.open("/"+wFile, FILE_WRITE);
if (tFile) {
Serial.println("Writing to "+wFile);
Serial.println("\n========= Entries ========");
for (auto txt : outList){
tFile.println(txt);
Serial.println(txt);
tFile.close();
Serial.println("error opening "+wFile);
Additional Textfiles
FileA.txt:
0,B123,USUARIO TESTE,E5
1,X001,SERGIO FRANCA,F1
2,H002,LUCCA DA MATA,F2
3,M789,EMILLY MONTEIRO,F3
4,S111,JOANA FRANCA,EM1
FileB.txt
0,B123,USUARIO TESTE,E5,segunda-feira,31-07-2023,19:58:00
1,X001,SERGIO FRANCA,F1,segunda-feira,31-07-2023,19:58:00
2,H002,LUCCA DA MATA,F2,segunda-feira,31-07-2023,19:58:00
If yes - provided that you have copied the two files FileA.txt and FileB.txt to the SD Card- the expected Serial output is:
Initializing SD card... initialization done.
Creating Index List from FileB.txt
B123
X001
H002
Evaluating FileA.txt
M789
S111
Writing to FileC.txt
Is something different or missing in your Serial output?
If yes, what is it?
