Functions and arrays issues
Hey guys, Super newbie here. im working on tutorials on the Arduino starter book. project 2 is the spaceship interface. Super basic and easy but i decided to attempt to add functions and arrays to practice that side of things.
object. LED 3 stays on when button is LOW
when button is HIGH, LED 2 and LED 3 blink on and off.
When button is released again it goes back to relax function.(LED3 HIGH only)
Whats happening now is when i release the button its stuck in the toggleLED function and pauses in that state and will not go to relax state.
What am i doing wrong here?
#define LED_1_PIN 12
#define LED_2_PIN 11
#define LED_3_PIN 10
#define BUTTON_PIN 2
#define LED_PIN_ARRAY_SIZE 3
int LEDBlinkState = 1;
byte LEDPinArray[LED_PIN_ARRAY_SIZE] =
      {LED_1_PIN, LED_2_PIN, LED_3_PIN};
void relax ()
    digitalWrite(LED_1_PIN, LOW);
    digitalWrite(LED_2_PIN, LOW);
    digitalWrite(LED_3_PIN, HIGH);
void setLEDPinModes()
  for (int i = 0; i < LED_PIN_ARRAY_SIZE; i++) {
    pinMode(LEDPinArray[i], OUTPUT);
void turnOffAllLEDs()
    digitalWrite(LEDPinArray[i], LOW);
void toggleLEDs()
  if (LEDBlinkState == 1) {
    digitalWrite(LED_1_PIN, HIGH);
    digitalWrite(LED_3_PIN, LOW);
    LEDBlinkState = 2;
  else {
    digitalWrite(LED_2_PIN, HIGH);
    LEDBlinkState = 1;
  pinMode(BUTTON_PIN, INPUT);
  setLEDPinModes();
  turnOffAllLEDs();
  if (digitalRead(BUTTON_PIN) == HIGH) {
    toggleLEDs();
    delay(300);
  else {
      relax;
You need a () here:
relax(); // not relax;
Wow, such a simple soultion. lol i thought my code was way off... Thank you very much!!
If you had Compiler warnings set to All in the IDE menu File, Preferences you would have received a warning:
... \AppData\Local\Temp\arduino_modified_sketch_996899\sketch_dec31b.ino: In function 'void loop()':
... \AppData\Local\Temp\arduino_modified_sketch_996899\sketch_dec31b.ino:63:12: warning: statement is a reference, not call, to function 'relax' [-Waddress]
relax;
... \AppData\Local\Temp\arduino_modified_sketch_996899\sketch_dec31b.ino:63:12: warning: statement has no effect [-Wunused-value]
May have saved you some time waiting for an answer from the forum.
This should be the default. Fixing warnings makes you a better programmer.
