Functions and calling functions
I'm new to arduino programming and tried lots of things to make this work but I dont know how to program functions using arduino for a project.
Code posted below.
Thanks in advance.
#define forward
int fO;
#define left
int lE;
#define right
int rI;
#define reverse
int rE;
void forward(){
  digitalWrite(7, HIGH);
  digitalWrite(8, LOW);
  digitalWrite(9, HIGH);
  digitalWrite(10, LOW);
void left(){
  digitalWrite(9, LOW);
  digitalWrite(10, HIGH);
void right(){
  digitalWrite(7, LOW);
  digitalWrite(8, HIGH);
void reverse(){
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
 // one output pin for each of the motors
 // 7 and 8 are the left and 9 10 are the right
  forward();
  left();
  right();
  reverse();
you wrote and called the functions correctly;
I just made some corrections and removed what was redundant.
See if this is how you want your code to work.
void forward(){
void left(){
void right(){
void reverse(){
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  forward();
  left();
  right();
  reverse();
Welcome to the forum
What is the purpose of the #defines and the variable declarations at the start of the sketch ?
thanks alot man a huge help and works great! :))
if your problem was solved, do a kindness to everyone on the forum, especially to those who helped you, write [Solved] before your topic title, so if someone searches and finds your topic, they'll know what the solution looks like.
And if it was solved by some help, please tick the one that best describes your solution.
