Hallo und Frohe Weihnachten erstmals.
Ich hab jetzt mein Code ein wenig verkleinert und wollte wissen, wie ich nun diese Funktion aufrufe. Allerdings möchte ich es nicht im Loop, weil es nur einmal aufgerufen werden soll. Wie mache ich das nun? Hier mein Code.
#include <Wire.h>
#define startbyte 0x0F
#define I2Caddress 0x07
int sv[2]={135,120}; // servo positions:0:tilt:13,1:open/close:5
int lmspeed,rmspeed; // left and right motor speed from -255 to +255 (negative value = reverse)
byte lmbrake,rmbrake; // left and right motor brake (non zero value = brake)
byte devibrate=50; // time delay after impact to prevent false re-triggering due to chassis vibration
int sensitivity=50; // threshold of acceleration / deceleration required to register as an impact
int lowbat=550; // adjust to suit your battery: 550 = 5.50V
byte i2caddr=7; // default I2C address of T'REX is 7. If this is changed, the T'REX will automatically store new address in EEPROM
byte i2cfreq=0; // I2C clock frequency. Default is 0=100kHz. Set to 1 for 400kHz
int stay () {
//stay
Serial.println("Stay");
lmspeed=0;
rmspeed=0;
MasterSend(startbyte,6,lmspeed,lmbrake,rmspeed,rmbrake,sv[0],sv[1],devibrate,sensitivity,lowbat,i2caddr,i2cfreq);
delay(200);
int forward () {
//forward
Serial.println("Forward");
lmspeed=60;
rmspeed=60;
delay(50); //50
for (int i = 0; i < 6; i++) {
MasterReceive(); // receive data packet from T'REX controller
delay(10); //50
int turn_right () {
//turn-right
Serial.println("Turn Right");
lmspeed=0;
rmspeed=90;
delay(10); //50
delay(10); //50
Wire.begin(); // no address - join the bus as master
Serial.println("Sample Program started!");
