Functions in IRremote Library
Hi!
Can you explain to me these functions in IRremote.h with their parameters and when should I use it?(give me a simple example please).
Thank you.
bool  isIdle     ( ) ;
void  custom_delay_usec (unsigned long uSecs);
		void  enableIROut 		(int khz) ;
		void  mark        		(unsigned int usec) ;
		void  space       		(unsigned int usec) ;
		void  sendRaw     		(const unsigned int buf[],  unsigned int len,  unsigned int hz) ;
isIdle(): True if the interface is currently not receiving any pattern.
custom_delay_usec(): A replacement for delayMicroseconds() that works with 32bit integers.
enableIROut(): Initializes the hardware to be able to produce the base wave at the desired frequency.
mark(): Sends a mark (active signal).
space(): Sends a space (inactive signal).
sendRaw(): sends a raw mark/space sequence, you specify the length of the mark and space items in the array in the first paramter, the lengh of that array is in the second parameter and the desired base wave frequency in the third.
All these functions are used inside the library so the library should be example enough. Usually you don't need to call these functions yourself.
pylon:
Thank You very much
