hi i have used the followin code for my line following robot built up using IR sensors:
int ir1 = 9;
int ir2 = 11;
int ir3 = 8;
int ir4=7;
int ir5=6;
int ir6=5;
int obstacle1=10;
int obstacle2=4;
int fwleft= 13;
int revleft=12;
int fwright= 14;
int revright= 15;
int val1=0;
int val2=0;
int val3=0;
int val4=0;
int val5=0;
int val6=0;
int pwm=0;
int flag=0;
pinMode(ir1, INPUT);
pinMode(ir2, INPUT);
pinMode(ir3, INPUT);
pinMode(ir4, INPUT);
pinMode(ir5, INPUT);
pinMode(ir6, INPUT);
pinMode(fwright, OUTPUT);
pinMode(revright, OUTPUT);
pinMode(fwleft, OUTPUT);
pinMode(revleft, OUTPUT);
int obs1,obs2;
obs1=analogRead(obstacle1);
obs2=analogRead(obstacle2);
val1=digitalRead(ir1);
val2=digitalRead(ir2);
val3=digitalRead(ir3);
val4=digitalRead(ir4);
val5=digitalRead(ir5);
val6=digitalRead(ir6);
if(val1==LOW && val2==LOW && val3==LOW && val4==LOW && val5==LOW && val6==LOW)
for(pwm = 0 ; pwm <= 60; pwm++) // fade in (from min to max)
digitalWrite(revleft, pwm);
digitalWrite(revright, LOW);
analogWrite(fwright, pwm);
analogWrite(fwleft, LOW);
flag=1;
if(val1==HIGH && val2==HIGH && val3==LOW && val4==LOW && val5==HIGH && val6==HIGH)
for(pwm = 0 ; pwm <= 80; pwm++) // fade in (from min to max)
analogWrite(fwleft, pwm);
digitalWrite(revleft, LOW);
flag=2;
if(val1==HIGH && val2==LOW && val3==LOW && val4==HIGH && val5==HIGH && val6==HIGH)
for(pwm = 0 ; pwm <= 50; pwm++) // fade in (from min to max)
digitalWrite(fwright, LOW);
analogWrite(revright, pwm);
flag=3;
if(val1==LOW && val2==LOW && val3==LOW && val4==HIGH && val5==HIGH && val6==HIGH)
flag=2;
if(val1==LOW && val2==HIGH && val3==HIGH && val4==HIGH && val5==HIGH && val6==HIGH)
flag=2;
if(val1==LOW && val2==LOW && val3==HIGH && val4==HIGH && val5==HIGH && val6==HIGH)
flag=4;
if(val1==HIGH && val2==HIGH && val3==HIGH && val4==LOW && val5==LOW && val6==HIGH)
flag=5;
if(val1==HIGH && val2==HIGH && val3==HIGH && val4==LOW && val5==LOW && val6==LOW)
flag=5;
if(val1==HIGH && val2==HIGH && val3==HIGH && val4==HIGH && val5==LOW && val6==LOW)
flag=6;
if(val1==HIGH && val2==HIGH && val3==HIGH && val4==HIGH && val5==HIGH && val6==LOW)
flag=6;
if(val1==HIGH && val2==HIGH && val3==HIGH && val4==HIGH && val5==HIGH && val6==HIGH)
if(obs1==0 && obs2==0)
if(obs1==0 && obs2!=0)
for(pwm = 0 ; pwm <= 35; pwm++) // fade in (from min to max)
if(obs1!=0 && obs2==0)
/*void reverse()
for(pwm = 0 ; pwm <= 200; pwm+=5) // fade in (from min to max)
the problem is my line follower is working fine if i don use functions..if i use functions such as front,reverse,etc...its not working when it follows line and goes out of control??is the delay encountered in calling a function and returnin is responsible for this??if so, how to rectify it?[code]
[/code]
