Hello!
I'm going to try and explain the situation as simply as possible, as it's a bit confusing :
The aim is to pick an LED at random to turn on and off again.
I have individual functions to do so on each separate LED.
I'm trying to make it possible to pick one of said functions, out of a list.
The randomly chosen function would then execute.
So I've been trying to make it possible for LED's to be chosen at random to turn on for 1 second, then off again, and for this to repeat. But being a newcomer to the Arduino (and C!), i'm having trouble finding the best way to do this. I was assuming a string of functions would work, but am not even sure if this is a possibility.
Any advice would be much appreciated, thanks in advance!
During the compilation process, names are converted to addresses. At run time, picking a function by name is NOT a possibility. You could use a series of if statements, using strcmp(), to determine if the name entered means anything. and, if it does, call the appropriate function.
Hackscribble:
Does each of the LED functions do something different with its respective LED when called? Or is the only difference the LED that it operates on?
A little update, the LED's must stay on until some input tells it to turn off. This shouldn't effect the main question though.
But yes, all functions do exactly the same thing. (Just with their own color)
Sounds like you should put the pin numbers for the LEDs in an array and just pick the array index at random. Then a single function would work with any LED.
This is further in to the project. But to turn the LED off, the user is required to press one of the switches (or buttons?), depending on whether the number of LED's turned on is odd or even.
Again, this is further on, and I would obviously need to find out how to turn on multiple random LED's at once!
I'm not sure I understand exactly what you're trying to do, but maybe:
#define NUMBEROFLEDSÂ 4
#define LOWPINÂ Â Â Â 8
#define HIPINÂ Â Â Â 11
int ledPins[NUMBEROFLEDS] = {LOWPIN, 9, 10, HIPIN};
long index;
long lastIndex;
 randomSeed(A0);
Â
 index = random(LOWPIN, HIPIN + 1);
Â
 // Code to set buttonOn and buttonOff
Â
 if (buttonOn == true) {
  turnOn(ledPins[index]);
  lastIndex = index;
  if (buttonOff == true) {
   turnOff(ledPins[lastIndex]);
  }  Â
