Hallo zusammen,
ich habe mir gestern bei Lidl ein Funksteckdosen Set gekauft.
Hier der Link zu der Modellanleitung.
Leider kann ich dies nicht auf dem gewohnten Weg mittels Tri-State ansteuern.
Zudem erhalte ich zwei verschieden Codes wenn ich mehrmals ein Taste auslese:
Hier mal der Code für Channel A
Wenn ich die Taste einmal drücke
ON
14:13:39.480 -> Decimal: 1112537811 (32Bit) Binary: 01000010010011111111101011010011 Tri-State: not applicable PulseLength: 702 microseconds Protocol: 2
14:13:39.617 -> Raw data: 7016,476,1520,1468,524,476,1516,476,1516,480,1516,472,1520,1472,520,476,1520,476,1524,1464,524,472,1520,476,1516,1472,520,1472,524,1480,516,1468,1096,396,352,1140,1096,396,1092,400,348,1140,352,1140,352,1092,400,1092,396,352,1140,352,1140,1092,400,1092,400,348,348,1144,352,1140,348,1148,348,
OFF
14:13:45.977 -> Decimal: 946772115 (32Bit) Binary: 00111000011011101001100010010011 Tri-State: not applicable PulseLength: 702 microseconds Protocol: 2
14:13:46.113 -> Raw data: 7016,476,1520,472,1516,1472,520,1472,524,1468,524,476,1516,476,1516,476,1516,476,1516,1472,520,1472,520,476,1516,1472,524,1468,524,1468,524,476,352,1140,348,1140,1096,396,352,1140,352,1140,352,1140,348,1140,396,352,1136,352,1140,352,1136,356,1136,352,1136,1096,352,1136,352,1144,348,1144,352,
Wenn ich allerdings die Taste gedrückt halte kommt noch folgender Code:
ON
14:15:56.687 -> Decimal: 467037587 (32Bit) Binary: 00011011110101100110110110010011 Tri-State: not applicable PulseLength: 702 microseconds Protocol: 2
14:15:56.825 -> Raw data: 7020,472,1520,472,1520,472,1520,1464,528,1464,528,472,1520,1468,528,1464,524,1464,528,1468,524,476,1516,1468,528,472,1520,1468,528,1464,524,472,348,1144,344,1148,1088,400,1088,404,344,1148,344,1144,348,1144,404,1088,400,1092,400,344,1148,1088,400,1092,400,348,348,1144,344,1148,348,1148,344,
14:15:57.140 ->
14:15:57.233 -> Decimal: 1112537811 (32Bit) Binary: 01000010010011111111101011010011 Tri-State: not applicable PulseLength: 702 microseconds Protocol: 2
14:15:57.369 -> Raw data: 7020,472,1520,1464,528,472,1520,472,1520,476,1516,472,1524,1464,524,472,1516,476,1520,1464,528,472,1520,472,1520,1468,524,1476,516,1468,524,1468,344,1148,1096,396,344,1144,344,1148,344,1144,348,1144,348,348,1144,348,1140,348,1144,1088,400,1092,400,1092,400,1088,352,1144,344,1144,348,1148,348,
14:15:57.689 ->
14:15:57.735 -> Decimal: 467037587 (32Bit) Binary: 00011011110101100110110110010011 Tri-State: not applicable PulseLength: 701 microseconds Protocol: 2
14:15:57.873 -> Raw data: 7020,472,1520,472,1516,476,1516,1468,524,1468,528,472,1516,1468,524,1476,528,1464,524,1468,528,472,1520,1464,524,472,1520,1468,524,1468,524,472,344,1144,1092,396,1092,404,1088,400,348,1144,344,1144,348,352,1140,348,1140,352,1140,1092,400,348,1140,348,1144,1092,348,1144,348,1144,344,1148,348,
14:15:58.195 ->
14:15:58.241 -> Decimal: 1112537811 (32Bit) Binary: 01000010010011111111101011010011 Tri-State: not applicable PulseLength: 701 microseconds Protocol: 2
14:15:58.421 -> Raw data: 7020,472,1520,1464,528,472,1516,472,1524,468,1520,472,1520,1464,528,472,1520,472,1520,1464,528,472,1520,472,1520,1464,528,1464,528,1464,528,1464,524,1468,524,1464,528,1468,524,1464,528,1464,528,472,1520,1464,528,468,1520,1472,520,1464,528,472,1520,1464,528,472,1524,464,1524,1460,528,1464,532,
14:15:58.739 ->
OFF
14:16:14.076 -> Decimal: 946772115 (32Bit) Binary: 00111000011011101001100010010011 Tri-State: not applicable PulseLength: 701 microseconds Protocol: 2
14:16:14.213 -> Raw data: 7020,472,1520,472,1528,1460,520,1468,524,1468,524,476,1516,472,1520,472,1520,472,1520,1464,528,1464,528,472,1516,1468,524,1468,528,1468,524,472,1092,400,348,1144,348,1140,1092,400,344,1144,352,1140,344,348,1140,1092,400,1092,400,1092,396,352,1140,1092,400,348,352,1140,348,1144,344,1152,352,
14:16:14.534 ->
14:16:14.581 -> Decimal: 201025747 (32Bit) Binary: 00001011111110110110100011010011 Tri-State: not applicable PulseLength: 702 microseconds Protocol: 2
14:16:14.719 -> Raw data: 7016,472,1520,472,1520,472,1516,472,1520,1464,528,472,1520,1464,528,1468,524,1464,528,1464,528,1464,528,1464,528,1464,528,472,1520,1464,528,1468,1088,404,344,1144,1092,404,340,1148,344,1144,348,1144,348,348,1144,1088,400,1092,400,348,1144,344,1144,1092,400,348,348,1144,344,1144,348,1148,348,
14:16:15.037 ->
14:16:15.082 -> Decimal: 946772115 (32Bit) Binary: 00111000011011101001100010010011 Tri-State: not applicable PulseLength: 702 microseconds Protocol: 2
14:16:15.220 -> Raw data: 7016,472,1520,472,1520,1464,528,1464,524,1476,520,472,1516,476,1516,476,1520,472,1516,1468,524,1468,528,472,1520,1468,524,1464,528,1468,524,476,352,1140,348,1144,1092,396,348,1144,344,1144,348,1144,348,1144,396,352,1140,348,1140,352,1140,348,1140,348,1144,1088,348,1144,348,1144,348,1144,352,
14:16:15.541 ->
14:16:15.587 -> Decimal: 201025747 (32Bit) Binary: 00001011111110110110100011010011 Tri-State: not applicable PulseLength: 701 microseconds Protocol: 2
14:16:15.768 -> Raw data: 7020,472,1520,472,1516,476,1520,472,1516,1468,524,476,1520,1464,524,1468,528,1464,524,1468,528,1464,524,1468,524,1468,524,472,1520,1464,528,1464,528,472,1520,1464,528,1464,528,472,1520,1464,528,472,1520,472,1516,472,1524,1460,528,1464,528,472,1520,1464,528,472,1516,476,1520,1464,528,1464,532,
14:16:16.089 ->
Zudem gibt es noch eine Master Taste, welche alle ein und ausschaltet.
Ich habe bis jetzt mal versucht den Dezimal wert und den Binärwert zu senden. Auch die verschiedenen nacheinander. Leider hat das nicht funktioniert.
Kann mir jemand vielleicht sagen, wie ich den Tri-State ermitteln kann oder was ich falsch mache?
