OK, I'm using a 644P chip with the bobuino variant pins_arduino.h file being used. So using the example sketch Basics/AnalogReadSerial, I tried each analog channel number using both their Ax value and their digital pin alias (14-21) I got the following results:
sketch software pin name used valid voltage reading shows up on shield pin
A0 (or14) A1 (15)
A1 (or15) A0 (14)
A2 (or16) A7 (21)
A3 (or17) A6 (20)
A4 (or18) A5 (19)
A5 (or19) A4 (18)
A6 (or20) A3 (17)
A7 (or21) A2 (16)
I tested the digital pin numbers using digitalRead command and sending them out the serial port and manipulated the pins with a ground after having enabled their internal pull-ups, and see no problem, pin mapping is correct for Bobuino D0 through D31 for digitalRead commands.
So the problem seems to be in the mapping of the analog channels numbers 0-7 to the correct digital pin numbers. Or maybe the mapping is correct but the analog mux selection bits are backwards or something?
Lefty
Variant pins_arduino.h file being used
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <avr/pgmspace.h>
// ATMEL ATMEGA1284P on Bobuino
// (D 4) PB0 1 | | 40 PA0 (D 21) AI 7
// (D 5) PB1 2 | | 39 PA1 (D 20) AI 6
// INT2 (D 6) PB2 3 | | 38 PA2 (D 19) AI 5
// PWM (D 7) PB3 4 | | 37 PA3 (D 18) AI 4
// PWM/SS (D 10) PB4 5 | | 36 PA4 (D 17) AI 3
// MOSI (D 11) PB5 6 | | 35 PA5 (D 16) AI 2
// PWM/MISO (D 12) PB6 7 | | 34 PA6 (D 15) AI 1
// PWM/SCK (D 13) PB7 8 | | 33 PA7 (D 14) AI 0
// RST 9 | | 32 AREF
// VCC 10 | | 31 GND
// GND 11 | | 30 AVCC
// XTAL2 12 | | 29 PC7 (D 29)
// XTAL1 13 | | 28 PC6 (D 28)
// RX0 (D 0) PD0 14 | | 27 PC5 (D 27) TDI
// TX0 (D 1) PD1 15 | | 26 PC4 (D 26) TDO
// INT0 RX1 (D 2) PD2 16 | | 25 PC3 (D 25) TMS
// INT1 TX1 (D 3) PD3 17 | | 24 PC2 (D 24) TCK
// PWM (D 30) PD4 18 | | 23 PC1 (D 23) SDA
// PWM (D 8) PD5 19 | | 22 PC0 (D 22) SCL
// PWM (D 9) PD6 20 | | 21 PD7 (D 31) PWM
#define NUM_DIGITAL_PINS 32
#define NUM_ANALOG_INPUTS 8
#define analogInputToDigitalPin(p) ((p < NUM_ANALOG_INPUTS) ? 21 - (p) : -1)
extern const uint8_t digital_pin_to_pcint[NUM_DIGITAL_PINS];
extern const uint16_t __pcmsk[];
extern const uint8_t digital_pin_to_timer_PGM[NUM_DIGITAL_PINS];
#define ifpin(p,what,ifnot) (((p) >= 0 && (p) < NUM_DIGITAL_PINS) ? (what) : (ifnot))
#define digitalPinHasPWM(p) ifpin(p,pgm_read_byte(digital_pin_to_timer_PGM + (p)) != NOT_ON_TIMER,1==0)
#define digitalPinToAnalogPin(p) ( (p) >= 14 && (p) <= 21 ? (p) - 14 : -1 )
#define analogPinToChannel(p) ( (p) < NUM_ANALOG_INPUTS ? NUM_ANALOG_INPUTS - (p) : -1 )
static const uint8_t SS = 10;
static const uint8_t MOSI = 11;
static const uint8_t MISO = 12;
static const uint8_t SCK = 13;
static const uint8_t SDA = 23;
static const uint8_t SCL = 22;
static const uint8_t LED = 13;
static const uint8_t A0 = 14;
static const uint8_t A1 = 15;
static const uint8_t A2 = 16;
static const uint8_t A3 = 17;
static const uint8_t A4 = 18;
static const uint8_t A5 = 19;
static const uint8_t A6 = 20;
static const uint8_t A7 = 21;
#define digitalPinToPCICR(p) ifpin(p,&PCICR,(uint8_t *)0)
#define digitalPinToPCICRbit(p) ifpin(p,digital_pin_to_pcint[p] >> 3,(uint8_t *)0)
#define digitalPinToPCMSK(p) ifpin(p,__pcmsk[digital_pin_to_pcint[]],(uint8_t *)0)
#define digitalPinToPCMSKbit(p) ifpin(p,digital_pin_to_pcint[p] & 0x7,(uint8_t *)0)
#ifdef ARDUINO_MAIN
#define PA 1
#define PB 2
#define PC 3
#define PD 4
const uint8_t digital_pin_to_pcint[NUM_DIGITAL_PINS] =
24, // D0 PD0
25, // D1 PD1
26, // D2 PD2
27, // D3 PD3
8, // D4 PB0
9, // D5 PB1
10, // D6 PB2
11, // D7 PB3
29, // D8 PD5
30, // D9 PD6
12, // D10 PB4
13, // D11 PB5
14, // D12 PB6
15, // D13 PB7
7, // D14 PA7
6, // D15 PA6
5, // D16 PA5
4, // D17 PA4
3, // D18 PA3
2, // D19 PA2
1, // D20 PA1
0, // D21 PA0
16, // D22 PC0
17, // D23 PC1
18, // D24 PC2
19, // D25 PC3
20, // D26 PC4
21, // D27 PC5
22, // D28 PC6
23, // D29 PC7
28, // D30 PD4
31, // D31 PD7
const uint16_t __pcmsk[] =
(uint16_t)&PCMSK0,
(uint16_t)&PCMSK1,
(uint16_t)&PCMSK2,
(uint16_t)&PCMSK3
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_mode_PGM[] =
NOT_A_PORT,
(uint16_t) &DDRA,
(uint16_t) &DDRB,
(uint16_t) &DDRC,
(uint16_t) &DDRD,
const uint16_t PROGMEM port_to_output_PGM[] =
NOT_A_PORT,
(uint16_t) &PORTA,
(uint16_t) &PORTB,
(uint16_t) &PORTC,
(uint16_t) &PORTD,
const uint16_t PROGMEM port_to_input_PGM[] =
NOT_A_PORT,
(uint16_t) &PINA,
(uint16_t) &PINB,
(uint16_t) &PINC,
(uint16_t) &PIND,
const uint8_t PROGMEM digital_pin_to_port_PGM[NUM_DIGITAL_PINS] =
PD, // D0
PD, // D1
PD, // D2
PD, // D3
PB, // D4
PB, // D5
PB, // D6
PB, // D7
PD, // D8
PD, // D9
PB, // D10
PB, // D11
PB, // D12
PB, // D13
PA, // D14
PA, // D15
PA, // D16
PA, // D17
PA, // D18
PA, // D19
PA, // D20
PA, // D21
PC, // D22
PC, // D23
PC, // D24
PC, // D25
PC, // D26
PC, // D27
PC, // D28
PC, // D29
PD, // D30
PD, // D31
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[NUM_DIGITAL_PINS] =
_BV(0), // D0 PD0
_BV(1), // D1 PD1
_BV(2), // D2 PD2
_BV(3), // D3 PD3
_BV(0), // D4 PB0
_BV(1), // D5 PB1
_BV(2), // D6 PB2
_BV(3), // D7 PB3
_BV(5), // D8 PD5
_BV(6), // D9 PD6
_BV(4), // D10 PB4
_BV(5), // D11 PB5
_BV(6), // D12 PB6
_BV(7), // D13 PB7
_BV(7), // D14 PA7
_BV(6), // D15 PA6
_BV(5), // D16 PA5
_BV(4), // D17 PA4
_BV(3), // D18 PA3
_BV(2), // D19 PA2
_BV(1), // D20 PA1
_BV(0), // D21 PA0
_BV(0), // D22 PC0
_BV(1), // D23 PC1
_BV(2), // D24 PC2
_BV(3), // D25 PC3
_BV(4), // D26 PC4
_BV(5), // D27 PC5
_BV(6), // D28 PC6
_BV(7), // D29 PC7
_BV(4), // D30 PD4
_BV(7), // D31 PD7
const uint8_t PROGMEM digital_pin_to_timer_PGM[NUM_DIGITAL_PINS] =
NOT_ON_TIMER, // D0 PD0
NOT_ON_TIMER, // D1 PD1
NOT_ON_TIMER, // D2 PD2
NOT_ON_TIMER, // D3 PD3
NOT_ON_TIMER, // D4 PB0
NOT_ON_TIMER, // D5 PB1
NOT_ON_TIMER, // D6 PB2
TIMER0A, // D7 PB3
TIMER1A, // D8 PD5
TIMER2B, // D9 PD6
TIMER0B, // D10 PB4
NOT_ON_TIMER, // D11 PB5
TIMER3A, // D12 PB6
TIMER3B, // D13 PB7
NOT_ON_TIMER, // D14 PA0
NOT_ON_TIMER, // D15 PA1
NOT_ON_TIMER, // D16 PA2
NOT_ON_TIMER, // D17 PA3
NOT_ON_TIMER, // D18 PA4
NOT_ON_TIMER, // D19 PA5
NOT_ON_TIMER, // D20 PA6
NOT_ON_TIMER, // D21 PA7
NOT_ON_TIMER, // D22 PC0
NOT_ON_TIMER, // D23 PC1
NOT_ON_TIMER, // D24 PC2
NOT_ON_TIMER, // D25 PC3
NOT_ON_TIMER, // D26 PC4
NOT_ON_TIMER, // D27 PC5
NOT_ON_TIMER, // D28 PC6
NOT_ON_TIMER, // D29 PC7
TIMER1B, // D30 PD4
TIMER2A, // D31 PD7
#endif // ARDUINO_MAIN
#endif // Pins_Arduino_h
// vim:ai:cin:sts=2 sw=2 ft=cpp
