Funny Gripe Responses
In case you need a laugh: Remember, it takes a college degree to fly a plane but only a high school diploma to fix one.
After every flight, Qantas pilots fill out a form, called a "Gripe Sheet" which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the Gripe Sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by Qantas' pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.
By the way, Qantas is the only major airline that has never, ever, had an accident.
P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft.
P: Something loose in cockpit. S: Something tightened in cockpit.
P: Dead bugs on windshield. S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute Descent. S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear. S: Evidence removed.
P: DME volume unbelievably loud. S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick. S: That's what friction locks are for.
P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield. S: Suspect you're right.
P: Number 3 engine missing. S: Engine found on right wing after brief search.
P: Aircraft handles funny........... S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums. S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit. S: Cat installed.
And the best one for last ..................
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from midget.
Funny but http://www.snopes.com/travel/airline/squawk.asp
It's definitely 1988. Yeah. Definitely 1988.
"Remember, it takes a college degree to fly a plane" Doesn't quite jive with solo a motor driven plane at 16, license at 17, here in the US anyway.
ooooooh, I'm all out of breath now... those are great! XD
I got those from a chain mail sent from my friends. I hate chain mails, but this one was pretty good.
