So, I got an old Lumex 16x1 LCD, hitachi 447xx whatever driver on it, but come to find out, this is one of those strange LCDs that actually operate as an 8x2, and needed a little coaxing to get it to work, not to mention, all I had was an ATMega 1280 laying around, so here is how I did it..
#include <LiquidCrystal.h>
LiquidCrystal lcd(48, 44, 34, 32, 30, 28);
char lcdbuffer[]="0123456789ABCDEF";
pinMode(46, OUTPUT); //READ/WRITE pin setup
digitalWrite(46, LOW); // READ/WRITE value
pinMode(50, OUTPUT); //CONTRAST pin setup
digitalWrite(50, LOW); //CONTRAST BEING TRIED W PULLUP, and potentiometer
delay(5); //DO IT! FOR suppressing transients
pinMode(52, OUTPUT); // vcc
digitalWrite(52, HIGH); // VCC - actually power on the LCD
// pinMode(48, OUTPUT); //REG SELECT // digitalWrite(48, LOW); // REG SELECT
// pinMode(44, OUTPUT); // ENABLE H,H/L (FALLING CLOCK ENABLE) // digitalWrite(44, LOW); // ENABLE
delay(10); // allow atmega board to settle
lcd.begin(16, 2); // for SOME reason you have to initialize it as a 16x2 here or it wont map
// the address space properly, so it will only init 8x1 in the loop after setup
delay(35); // allow lumex board to settle
lcd.setCursor(0, 0);
lcd.begin(8, 2);
} // END SETUP FUNCTION (ONE TIME INIT)
byte i=0;
char inChar;
while (Serial.available() > 0)
i=0;
delay(5); //allow serial to catch up
while(i < 17) // One less than the size of the array
inChar = Serial.read(); // Read a character
lcdbuffer[i] = inChar; // Store it
i++; // Increment where to write next
//lcd.clear();
for (i=0;i<16;i++)
if(i<8)
lcd.setCursor(i, 0);
lcd.write(lcdbuffer[i]);
if(i>7)
lcd.setCursor((i-8), 1);
delay(1); // sync time for each letter, draw rate
i=0;
delay(1500); //time to keep each 16x on screen
delay(5000); // refresh rate for messages (once buffer is cleared)
} //END VOID LOOP
So basically, I took the 14/16 pin connector and set pin 1 at ground (under pin 52) and just plugged it up the left side of digital I/O rail, and pulled the contrast pin low in code, but used a 10K between pin 2, VCC and it, to pull it up variably for contrast. So three parts. Arduino, LCD, singular trimpot.
In the setup it handles pulling things where they need to be, and since there's no backlight, no current concerns. Code basically pulls and parses/displays 16 char at a time. Hope this helps someone.
