Now the fuse holder pdf above says max power 1.6W and max current 6.3A .. does this mean that It is not suitable since the board draws about 6W ? Note the conducting path 0.1mm²
Hmm. It's not clear is it? I expect the fuseholder's wattage is in respect of the power dissipated by the fuse itself. If you have something other than a fuse inserted in that holder (maybe you're using a resistor for testing) then you want to keep its power dissipation under 1.6W.
Of course a fuse and the connections to the fuse have an unavoiable resistance, which will dissipate heat. This heating will be insignificant for your application.
MorganS:
In fact resistance for the 400ma fuse is 0.1610 ohm .. so if P = I²R the power dissipated is about 0,015W
