Futaba VFD 4x20 and SPI VFD problem
Hi Folks!
So I finally forced my vfd to work with arduino :), but I have some problem - when display split text it continues on third line and then go back to second like:
================================================= LINE #0 This is a very long text which LINE #1 go back to this line... LINE #2 continues on this line and then
LINE #3
I think it's some problem with automatic splitting text (it jumps two lines down not just one).
I can manually set position of cursor and it works fine. Also I set in setup(); a dimensions for my display (AFAIK default is 2x20 so I set to 4x20).
Where should I change this correctly?
Thanks
This "feature" is expected with HD44780 and compatible displays. It has something to do with display memory arrangement:
http://web.alfredstate.edu/weimandn/lcd/lcd_addressing/lcd_addressing_index.html
To avoid this, develop your own function to split and print to the right lines, or restrict all messages to 20 characters at a time.
That’s strange but OK I’ll modify my methods.Thanks :slight_smile:
