Fysetc 7inch display with arduino mega 2560
HI. I have a display which I have bought for controlling a 3D printer along with duet3D board. Its a Fysetc 7.0'' 800x480 V1.1 display which is based on Paneldue v3.0 display. I want to use this display with the arduino mega that I have but I don't know how to do this. The display looks similar to other 7'' displays like SSD1963 or DWIN. Can I use the same libraries as these? Also the display that I have has Tx Rx pins and a separate 10pin module. Has anyone worked with this? Please help me out with this
You can use standard Arduino Serial communication libraries to interact with the PanelDue-based display.
What all libraries will work? like, can I use the ssd1306 library on this board with the tx rx?
SSD1306 uses SPI communication protocol. You need to use VCC,GND,SCL.SDA pins for this display. Tx,Rx not needed.
