g_ServoOut.update()
the g_ServoOut.update() in the loop wont work. in the setup the servo moves to the middle and stays there.
anybody knows why?
#include <ServoOut.h>
#include <Timer1.h>
#define SERVOS 1
uint8_t  g_pinsOut[SERVOS] = {
  2};    // Output pins
uint16_t g_input[SERVOS];                     // Input buffer for servoOut, microseconds
uint8_t  g_work[SERVOOUT_WORK_SIZE(SERVOS)];  // we need to have a work buffer for the ServoOut class
rc::ServoOut g_ServoOut(g_pinsOut, g_input, g_work, SERVOS);
int dir = 1;
int i=1500;
  rc::Timer1::init();
  for (uint8_t i = 0;  i < SERVOS; ++i)
    // set up output pins
    pinMode(g_pinsOut[i], OUTPUT);
    // put them low
    digitalWrite(g_pinsOut[i], LOW);
    // fill input buffer, convert raw values to normalized ones
    g_input[i] = (1500);
  g_ServoOut.start();
  delay(100);
  switch (dir){
    case 0:
    if (i>1000)
 Serial.println("dir 0");
     g_input[1] = i;
     --i;
    dir=1;
  case 1:
    if (i<2000)
     Serial.println("dir 1");
    g_input[1] = i;
    ++i;
    dir=0;
  Serial.println(g_input[1]);
  g_ServoOut.update();
What does the ServoOut library do that is different from the regular Sevo library?
Where did you get it - do you have a link?
...R
its thr rc library...
CanDo:
You haven't said what is different about it and why you are using it rather than the regular Servo library that comes with the Arduino IDE and with which most people are familiar.
...R
