Gadgets with E-Paper Displays Collection
This topic is intended to provide links to gadgets with e-paper displays, and information and discussions about them.
I will add links to devices I know to this first post in this topic. Contributions are welcome!
The temperature and humidity meter gadget that got me starting this topic: Xiaomi MiaoMiaoCe INK Dispay Digital Moisture Meter High-Precision Thermometer And the post that pointed me to it: #838
A nice weather station: https://thingpulse.com/product/espaper-plus-kit-wifi-epaper-display/
some nice links, I've just ordered a 4.2" waveshare -look out for ther dumb questions!
I just received my https://www.aliexpress.com/item/Xiaomi-MiaoMiaoCe-INK-Dispay-Digital-Moisture-Meter-High-Precision-Thermometer-Temperature-Humidity-Probe-Monitor-Sensor/32849412575.html
I was surprised how exact the measured temperature and humidity is, until I opened the case for a look at the board and the devices on that board.
The sensor is a SHT30, so this is no surprise, I use SHT31 sensors from Sensirion, a Swiss sensor producer, for my sensor network. You can get these sensors mounted on practical boards by Chinese suppliers, or even on a board for Wemos D1 mini (LOLIN).
The processor is a Holtek HT66F0182 8bit microcontroller.
The e-paper display contains the inking WFT0000CF41 on the flex cable. Google knows nothing about it. The e-papers from Good Display also have WFT... marks on the flex cables; don't know if this means it comes from them, or just the flex cable comes from the same source.
The signals are not easily accessible, I would need an interconnector like gcormier used.
The e-paper seems to be glued from the front side to the case, so I can't see if there is any device on it, but it looks like the glass is slightly extended on one edge.
I would check if the controller chip is the following:
https://www.holtek.com/documents/10179/116711/HT16E07v100.pdf
Being from the same brand, could be the one which is receiving the signals from the microcontroller.
