Galileo Ethernet
Hi arduino community...
I have an Intel Galileo Gen2 and I am trying to use the Ethernet. When I run WebClient, from the following code
  Web client
 This sketch connects to a website (http://www.google.com)
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 created 18 Dec 2009
 modified 9 Apr 2012
 by David A. Mellis
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {  0x98, 0x4f, 0xee, 0x01, 0x8d, 0xdf };
IPAddress server(173,194,33,104); // Google
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  // give the Ethernet shield a second to initialize:
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET /search?q=arduino HTTP/1.0");
    client.println();
  else {
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    for(;;)
And open the Serial Monitor, I get the following outputs:
connecting...
connection failed
disconnecting.
The ChatServer example seems to work, though. Trying to figure out if this is a router problem, code problem, or galileo problem.
Any help is greatly appreciated,
awesomeness01
Simple client test code you can try unmodified to see if you can get a response from the server.
//zoomkat 3-1-13
//simple client checkip test
//for use with IDE 1.0.1 or later
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // test web page server
void setup(){
    while(true);
  Serial.println("Better client ip test 3/1/13"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    client.println("GET / HTTP/1.1"); //download text
    client.println("Host: checkip.dyndns.com");
    client.println("Connection: close");  //close 1.1 persistent connection
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("==================");
  client.stop(); //stop client
Got connection failed, disconnecting. Please explain what this does?
awesomeness01:
It makes a client request to an IP server and functions like any other device connected to your router. Make sure you do not have an SD card inserted in the ethernet shield SD slot. This code works with an arduino, so YMMV with the Galileo.
Thank you very much for your help. It turns out all I had to do was run the command, system("ifup eth0"), and It worked fine. Not sure why, though.
