I did this a while ago and have stopped working on it as I have lost interest in the LCD as it is kind of slow.
The LCD I used can be found here:
http://www.seeedstudio.com/depot/320240-graphic-lcd-w-touch-screen-and-hw-accel-p-147.html?cPath=8
I got most of the hardware functions working; I never did try to get the sprites working. The library I created is in the next two posts.
Anyway here is my implementation of the game of life on a 320x240 color lcd.
there are 40x30 cells as the only way I could get a reasonable amount of speed out of the LCD was to feed it the data as special characters that are either a blank character of solid block character.
Anyway here is the life sketch:
#include <TCB8000C.h>
#include <stdlib.h>
#define ALIVE 1
#define DEAD 0
#define bheight 30
#define bwidth 40 // must be devisable by 8
#define ALIVEch 219
#define DEADch 255
char cdisplay = 0;
char cbuff = 1;
unsigned int generation = 0;
unsigned int buffer[16];
int count = 0;
unsigned char board[2][bheight][bwidth/8] = {
//board 0
//0 8 16 24 32
{{B00000000,B00000000,B00000000,B00000000,B00000000}, //0
{B00000000,B00000000,B00000000,B01000000,B00000000}, //1
{B00000000,B00000000,B00000001,B01000000,B00000000}, //2
{B00000000,B00000110,B00000110,B00000000,B00011000}, //3
{B00000000,B00001000,B10000110,B00000000,B00011000}, //4
{B01100000,B00010000,B01000110,B00000000,B00000000}, //5
{B01100000,B00010001,B01100001,B01000000,B00000000}, //6
{B00000000,B00010000,B01000000,B01000000,B00000000}, //7
{B00000000,B00001000,B10000000,B00000000,B00000000}, //8
{B00000000,B00000110,B00000000,B00000000,B00000000}, //9
{B00000000,B00000000,B00000000,B00000000,B00000000}, //10
{B00000000,B00000000,B00000000,B00000000,B00000000}, //11
{B00000000,B00000000,B00000000,B00000000,B00000000}, //12
{B00000000,B00000000,B00000000,B00000000,B00000000}, //13
{B00000000,B00000000,B00000000,B00000000,B00000000}, //14
{B00001110,B00111000,B00000000,B00000000,B00000000}, //15
{B00000000,B00000000,B00000000,B00000000,B00000000}, //16
{B00100001,B01000010,B00000000,B00000000,B00000000}, //17
{B00100001,B01000010,B00000000,B00000000,B00000000}, //18
{B00100001,B01000010,B00000000,B00000000,B00000000}, //19
{B00001110,B00111000,B00000000,B00000000,B00000000}, //20
{B00000000,B00000000,B00000000,B00000000,B00000000}, //21
{B00001110,B00111000,B00000000,B00000000,B00000000}, //22
{B00100001,B01000010,B00000000,B00000000,B00000000}, //23
{B00100001,B01000010,B00000000,B00000000,B00000000}, //24
{B00100001,B01000010,B00000000,B00000000,B00000000}, //25
{B00000000,B00000000,B00000000,B00000000,B00000000}, //26
{B00001110,B00111000,B00000000,B00000000,B00000000}, //27
{B00000000,B00000000,B00000000,B00000000,B00000000}, //28
{B00000000,B00000000,B00000000,B00000000,B00000000}}, //29
//board 1
//0 8 16 24 32
{B00000000,B00000000,B00000000,B00000000,B00000000}, //3
{B00000000,B00000000,B00000000,B00000000,B00000000}, //4
{B00000000,B00000000,B00000000,B00000000,B00000000}, //5
{B00000000,B00000000,B00000000,B00000000,B00000000}, //6
{B00000000,B00000000,B00000000,B00000000,B00000000}, //7
{B00000000,B00000000,B00000000,B00000000,B00000000}, //8
{B00000000,B00000000,B00000000,B00000000,B00000000}, //9
{B00000000,B00000000,B00000000,B00000000,B00000000}, //15
{B00000000,B00000000,B00000000,B00000000,B00000000}, //17
{B00000000,B00000000,B00000000,B00000000,B00000000}, //18
{B00000000,B00000000,B00000000,B00000000,B00000000}, //19
{B00000000,B00000000,B00000000,B00000000,B00000000}, //20
{B00000000,B00000000,B00000000,B00000000,B00000000}, //22
{B00000000,B00000000,B00000000,B00000000,B00000000}, //23
{B00000000,B00000000,B00000000,B00000000,B00000000}, //24
{B00000000,B00000000,B00000000,B00000000,B00000000}, //25
{B00000000,B00000000,B00000000,B00000000,B00000000}, //27
{B00000000,B00000000,B00000000,B00000000,B00000000}} //29
// drawing functions:
void display();
void printStatus();
// life game functions:
char isAlive(int x, int y);
void update();
char neighbors(int x, int y);
void setCell(int x, int y, int b, char status);
init_lcd();
display();
printStatus();
update();
char isAlive(int x, int y) {
int xindex = x >> 3; // shift operation is is the same as (x-1)/8
int bit = x & B00000111; // same as
char mask = B10000000 >> bit;
return board[cdisplay][y][xindex] & mask;
void update() {
char count;
for (int y = 0; y < bheight; y++) {
for (int x = 0; x < bwidth; x++) {
count = neighbors(x,y);
if ( count == 3 )
setCell(x,y,cbuff,ALIVE);
else if ( isAlive(x,y) && count == 2 )
setCell(x,y,cbuff,DEAD);
if ( cdisplay == 1) {
cdisplay = 0;
cbuff = 1;
else {
cdisplay = 1;
cbuff = 0;
generation++;
char neighbors( int x, int y ) {
char count = 0;
if ( x > 0 && x < bwidth-1 && y > 0 && y < bheight-1 ) {
// 3 above
if ( isAlive(x-1,y-1) ) count++;
if ( isAlive(x,y-1) ) count++;
if ( isAlive(x+1,y-1) ) count++;
// 2 to each side
if ( isAlive(x-1,y) ) count++;
if ( isAlive(x+1,y) ) count++;
// 3 below
if ( isAlive(x-1,y+1) ) count++;
if ( isAlive(x,y+1) ) count++;
if ( isAlive(x+1,y+1) ) count++;
else if ( x == 0 && y == 0 ) {
else if ( x == bwidth-1 && y == bheight-1 ) {
else if ( x == 0 ) {
else if ( x == bwidth-1 ) {
else if ( y == 0 ) {
else {
return count;
void setCell(int x, int y, int b, char status) {
if (status)
board[b][y][xindex] = board[b][y][xindex] | mask;
board[b][y][xindex] = board[b][y][xindex] & ~mask;
void display() {
char string_line[41];
set_color_fg_font(RED);
set_color_bg(BLACK);
string_line[40] = '\0';
if( isAlive(x,y) )
string_line[x] = ALIVEch;
string_line[x] = DEADch;
print_string(0,y*8,(unsigned char *)string_line, 's');
void printStatus() {
char buf[6];
set_color_fg(WHITE);
print_string(0,232,(unsigned char*)"Generation:",'s');
itoa(generation, buf, 10);
print_string(96,232,(unsigned char*)buf,'s');
