Im new to arduino and i have made a led matrix. I found this code online for an 8x8 matrix it is the game of life. I would like it to restart by itself can some one pleas help me.
#include <EEPROM.h>
GAME OF LIFE
For an 8x8 LED matrix
Connect digital IO pins 2-13 and analog pins 0-3 to LED matrix (through current limiting resistors)
Analog pin 4 (see RANDOMIZER_ANALOG_PIN) is used to select the randomization mode.
- connect to 5V to randomize and generate a new rand seed
- connect to 3.3V to use the last randomized set (USE_EEPROM must be #defined)
- connect to 0V to use the hard coded starting state
Analog pin 5 (see UNCONNECTED_ANALOG_PIN) is left unconnected and used to add a bit of true randomness to seed the RNG
const int NUMROWS = 8;
const int NUMCOLS = 8;
const int MICROS = 100;
const int EEPROM_ADDRESS_1 = 34;
const int EEPROM_ADDRESS_2 = 35;
const byte rows[NUMROWS] = { 15, 7, 6, 5, 2, 3, 4, 14 };
* I'm using only one of the colors in the LED matrix.
const byte cols[NUMCOLS] = { 17, 13, 12, 11, 8, 9, 10, 16 };
const int RANDOMIZER_ANALOG_PIN = 4;
const int UNCONNECTED_ANALOG_PIN = 5;
* Conditional compilation directives
//#define USE_EEPROM 1 // uncomment this line to enable eeprom storage
//#define SHOW_STARTUP_SEQUENCE 1 // uncomment this line to enable the startup sequence
boolean gameBoard[NUMROWS][NUMCOLS] = {
{ 0, 0, 0, 0, 0, 0, 0, 0 },
{ 0, 0, 1, 1, 0, 0, 0, 0 },
{ 0, 1, 1, 0, 0, 0, 0, 0 },
{ 0, 0, 1, 0, 0, 0, 0, 0 },
boolean newGameBoard[NUMROWS][NUMCOLS] = {
Serial.println("\nBegin setup()");
#ifdef USE_EEPROM
Serial.println("EEPROM code enabled");
#else
Serial.println("EEPROM code disabled");
#endif // defined USE_EEPROM
allOff();
startupSequence();
setUpInitialBoard();
Serial.println("End setup()\n");
long time = millis();
// Display the current game board for approx. 250ms
do {
displayGameBoard();
while (millis() < time + 250);
// Calculate the next iteration
calculateNewGameBoard();
swapGameBoards();
* Turns off all LEDs, and initializes the pin modes correctly.
void allOff() {
for (int i=0; i<NUMROWS; i++) {
pinMode(rows[i], INPUT);
for (int i=0; i<NUMCOLS; i++) {
pinMode(cols[i], OUTPUT);
digitalWrite(cols[i], LOW);
* Does some randomizing of the initial board state.
void setUpInitialBoard() {
// Generate a new seed for the RNG
int seed = analogRead(UNCONNECTED_ANALOG_PIN);
// Look at how the randomizer pin is connected.
// If it's pulled high, then generate and store a new seed.
// If it's middle (3.3v) then read the seed from EEPROM (if that code is enabled with USE_EEPROM)
pinMode(RANDOMIZER_ANALOG_PIN, INPUT);
int randomizerPinValue = analogRead(RANDOMIZER_ANALOG_PIN);
if (randomizerPinValue > 900) { // connected to +5V
#ifdef USE_EEPROM
// Generate and store a new random seed
Serial.println("Generating new randseed...");
Serial.print("Storing ");
Serial.print(seed, DEC);
EEPROM.write(EEPROM_ADDRESS_1, lowByte(seed));
EEPROM.write(EEPROM_ADDRESS_2, highByte(seed));
Serial.print("... done\n");
Serial.print("Seeding RNG with ");
Serial.print("\n");
randomSeed(seed);
perturbInitialGameBoard();
} else if (randomizerPinValue > 300) { // connected to +3.3V
// Retrieve random seed from EEPROM
#ifdef USE_EEPROM
Serial.println("Retrieving randseed...");
int hi = EEPROM.read(EEPROM_ADDRESS_2);
int lo = EEPROM.read(EEPROM_ADDRESS_1);
seed = (hi << 8 ) | lo;
Serial.print("Read ");
Serial.print("\n");
Serial.print("\n");
randomSeed(seed);
Serial.println("Using basic board.");
* Does a nice little animation to aid visual checks that all LEDs are correctly connected and operating.
* Lights every LED in each row, going back and forth across the rows, from top to bottom.
void startupSequence() {
#ifdef SHOW_STARTUP_SEQUENCE
for (int row=0; row<NUMROWS; row++) {
if (row%2 == 0) {
for (int col=0; col<NUMCOLS; col++) {
setLedOn(row, col);
delay(25);
setLedOff(row, col);
for (int col=NUMCOLS-1; col>=0; col--) {
setLedOn(row, col);
delay(25);
#endif // defined SHOW_STARTUP_SEQUENCE
* Makes a small number of random changes to the game board
void perturbInitialGameBoard() {
int numChanges = random(20,100);
for (int i=0; i<numChanges; i++) {
int row = random(0, NUMROWS);
int col = random(0, NUMCOLS);
gameBoard[row][col] = !gameBoard[row][col]; // toggle the led in this position
* Loops over all game board positions, and briefly turns on any LEDs for "on" positions.
void displayGameBoard() {
for (byte row=0; row<NUMROWS; row++) {
for (byte col=0; col<NUMCOLS; col++) {
if (gameBoard[row][col]) {
pulseLed(row, col);
* Turns on the specified LED for a v. short period of time
void pulseLed(byte row, byte col) {
setLedOn(row, col);
delayMicroseconds(MICROS);
* Counts the number of active cells surrounding the specified cell.
* Cells outside the board are considered "off"
* Returns a number in the range of 0 <= n < 9
byte countNeighbors(byte row, byte col) {
byte count = 0;
for (char rowDelta=-1; rowDelta<=1; rowDelta++) {
for (char colDelta=-1; colDelta<=1; colDelta++) {
// skip the center cell
if (!(colDelta == 0 && rowDelta == 0)) {
if (isCellAlive(rowDelta+row, colDelta+col)) {
count++;
return count;
* Returns whether or not the specified cell is on.
* If the cell specified is outside the game board, returns false.
boolean isCellAlive(char row, char col) {
if (row < 0 || col < 0 || row >= NUMROWS || col >= NUMCOLS) {
return false;
return (gameBoard[row][col] == 1);
* Encodes the core rules of Conway's Game Of Life, and generates the next iteration of the board.
* Rules taken from wikipedia.
void calculateNewGameBoard() {
byte numNeighbors = countNeighbors(row, col);
if (gameBoard[row][col] && numNeighbors < 2) {
// Any live cell with fewer than two live neighbours dies, as if caused by under-population.
newGameBoard[row][col] = false;
} else if (gameBoard[row][col] && (numNeighbors == 2 || numNeighbors == 3)) {
// Any live cell with two or three live neighbours lives on to the next generation.
newGameBoard[row][col] = true;
} else if (gameBoard[row][col] && numNeighbors > 3) {
// Any live cell with more than three live neighbours dies, as if by overcrowding.
} else if (!gameBoard[row][col] && numNeighbors == 3) {
// Any dead cell with exactly three live neighbours becomes a live cell, as if by reproduction.
// All other cells will remain off
* Copies the data from the new game board into the current game board array
void swapGameBoards() {
gameBoard[row][col] = newGameBoard[row][col];
void setLed(byte row, byte col, boolean level) {
if (level == HIGH) {
pinMode(rows[row], OUTPUT);
digitalWrite(cols[col], HIGH);
else if (level == LOW) {
pinMode(rows[row], INPUT);
digitalWrite(cols[col], LOW);
void setLedOn(byte row, byte col) {
setLed(row, col, HIGH);
void setLedOff(byte row, byte col) {
setLed(row, col, LOW);
