Game with 16x2 LCD screen - collision detection
Hi! I'm working on a final project for one of my classes and decided to make a simple platforming game. However, I'm having trouble with the collision detection of blocks. Right now the player controlled sprite just gets printed in the same space as the block.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // RS, E, D4, D5, D6, D7
byte AMONGUS[] =
  B01110,
  B10001,
  B10111,
  B10101,
  B10111,
  B10001,
  B10101,
  B11011
byte Block[]
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
int joyPosY;
int joyPosX;
int col;
  // Specify the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Create new characters:
  lcd.createChar(0, AMONGUS);
  // Clears the LCD screen:
  lcd.clear();
  pinMode(A0, INPUT); //sets pin A0 to input info
  pinMode(A1, INPUT);
void bottomRowMove()
  if(joyPosX >= 400)
    lcd.clear();
    col++;
  else if(joyPosX <= 300)
    lcd.clear();
    if(col > 0)
      col--;
      col = 0;
void upperRowMove()
  if(joyPosX >= 520)
    lcd.clear();
    if(col < 16)
      col++;
      col = 15;
    lcd.clear();
    if(col > 0)
      col--;
      col = 0;
void placeBlocks()
  lcd.createChar(1, Block);
  lcd.setCursor(4,1);
  lcd.write(byte(1));
  lcd.setCursor(7, 0);
  lcd.write(byte(1));
  joyPosY = analogRead(A0);
  joyPosX = analogRead(A1);
  Serial.print("X Pos: ");
  Serial.println(joyPosX);
  Serial.print("Y Pos: ");
  Serial.println(joyPosY);
  lcd.clear();
  // Print all the custom characters:
  lcd.setCursor(col, 1);
  lcd.write(byte(0));
  placeBlocks();
  while(joyPosY >= 900)
    lcd.clear();
    placeBlocks();
    lcd.setCursor(col, 0);
    lcd.write(byte(0));
    delay(100);
    upperRowMove();
  delay(100);
  bottomRowMove();
Take a minute, read and follow this link: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
What are You talking about? Collision detector? Helpers are not standing behind You looking over Your shoulder.
Schematics, pictures, links to datasheets. Please upgrade Your post.
What do you expect to happen when there is a collision?
Looks like you always put the blocks in the same place... col/row 4,1 and 7,0... so in the routines that are moving the sprite you need to check whether the col/row you just calculated is the same as where the blocks are... then do whatever.
