Gameduino for Intel Galileo.
Hello,
I have recently bought an Intel Galileo and a Gameduino shield, however when I go to program using the Arduino/Intel Galileo programming program I get a load of errors. I have added all the correct libraries.
I tried the same code on the regular Arduino programming program and I got no errors when I verified the code however this program in incompatible with the Intel Galileo.
Please Help!! :slight_smile:
PS: when I say the "Arduino/Intel Galileo programming program" I mean the IDE
PPS: These are the errors I receive when using the Arduino/Intel Galileo programming program :
Arduino: 1.5.3 (Windows 7), Board: "Intel® Galileo Gen2
C:\arduino-1.5.3/hardware/tools/x86/i686-pokysdk-mingw32/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-g++ -m32 -march=i586 --sysroot=C:\arduino-1.5.3/hardware/tools/x86/i586-poky-linux-uclibc -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -D__ARDUINO_X86__ -Xassembler -mquark-strip-lock=yes -march=i586 -m32 -DARDUINO=153 -IC:\arduino-1.5.3\hardware\arduino\x86\cores\arduino -IC:\arduino-1.5.3\hardware\arduino\x86\variants\galileo_fab_g -IC:\arduino-1.5.3\hardware\arduino\x86\libraries\SPI -IC:\Users\Edward\Documents\Arduino\libraries\Gameduino C:\Users\Edward\AppData\Local\Temp\build1589179656806897591.tmp\sprites256.cpp -o C:\Users\Edward\AppData\Local\Temp\build1589179656806897591.tmp\sprites256.cpp.o
In file included from sprites256.ino:2:0:
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h:50:39: error: 'prog_uchar' has not been declared
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h:61:25: error: 'prog_uchar' has not been declared
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h:62:45: error: 'prog_uchar' has not been declared
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h: In member function 'int Asset::open(const char*, ...)':
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h:183:7: error: 'va_list' was not declared in this scope
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h:183:15: error: expected ';' before 'ap'
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h:184:16: error: 'ap' was not declared in this scope
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h:184:21: error: 'va_start' was not declared in this scope
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h:192:24: error: expected primary-expression before 'const'
C:\Users\Edward\Documents\Arduino\libraries\Gameduino/GD.h:192:36: error: 'va_arg' was not declared in this scope
In file included from sprites256.ino:4:0:
pickups2.h: At global scope:
pickups2.h:1:16: error: 'prog_uchar' does not name a type
pickups2.h:887:16: error: 'prog_uchar' does not name a type
In file included from sprites256.ino:5:0:
sprites256.h:1:16: error: 'prog_uchar' does not name a type
sprites256.h:275:16: error: 'prog_uchar' does not name a type
sprites256.h:530:16: error: 'prog_uchar' does not name a type
sprites256.ino: In function 'void setup()':
sprites256.ino:60:20: error: 'sprites256_pic' was not declared in this scope
sprites256.ino:61:20: error: 'sprites256_chr' was not declared in this scope
sprites256.ino:62:20: error: 'sprites256_pal' was not declared in this scope
sprites256.ino:64:23: error: 'pickups2_img' was not declared in this scope
sprites256.ino:65:23: error: 'pickups2_pal' was not declared in this scope
Please don't crosspost, putting the same question in multiple places. One topic, one discussion. Post, and have a little patience please.
Duplicate post deleted.
