Gaming Allowance Based on Sleep
Hi Forum,
I am a student trying to make a device that helps people improve sleep by giving computer allowance based on the amount of sleep the night before.
The code I have now (attached) is pretty much finished and works but there's something I want to improve. The device detects sleeping and waking up with a pressure sensor under the pillow (this is in mode=2), but as soon as I move my head off the pillow it thinks I've woken up. How do I make it so that it waits 5 minutes after detecting pressure to assume 'asleep' and 5 minutes after no pressure before assuming 'awake'?
Another thing, in (mode=4) I made the LEDs countdown the allowance but after it's done the last LED stays lit. I put [fill_solid(leds, 30, CRGB::Black);] but it didn't do anything.
Thanks in advance,
Chris
pressure_3.6.ino (2.43 KB)
You might be able to use millis() to do that. Something like
unsigned long lastTime = 0;
//then in the loop:
if(pressure < 900 && wasJustAsleep){
    lastTime = millis();
if (millis - lastTime > 300000){//5 minutes since lastTime was set to millis
sleeping = false;
Of course, that will all have to be integrated with the rest of the code.
