Garage Parking System & Door Controller
Newbie here that has only heard of Arduino recently but am interested in attempting some design of a couple things for around the house, and eventually running a low voltage lighting system inside the home as well as landscaping and possibly running irrigation in the future.
I would like my first project to be in the garage and handling the garage door as well as a proximity sensor for aiding in parking both my wife's car as well as mine perfectly in the garage each time.
This may sound difficult at first but I am thinking fairly feasible.
Design / Wants:
  1. Open/Close the Garage Door
  2. Verify Garage Door is Open/Close via a relay/light or better yet, through a web browser via the wifi or ethernet capability.
  3. I would like to have a set of LED's or Lights that would depict me to continue pulling forward and left or right depending on the cars orientation. I am guessing I would need some sensor that could measure the distance based on sonar/radar detection. I would like for it to be where I could use any car in the parking lot as long as I clear the garage door sensors so the garage door can close without obstruction.
Would-Likes:
  1. Of Course Web style controlling. (shutting door or monitoring status, via web browser on mobile device)
  2. Run the system off a clock and if the door is still open around midnight and no movement inside, automatically close the door or sound an alarm/light. Or maybe a no movement in 1-2 hours, sound an alarm/light before attempting to close the door.
A little background:
A hobbyist at heart, into Electric R/C Helicopters, Deal with electrical systems (relays, transformers, plc, etc.) during daily job, familiar and can solder, have a true rms DMM & AMProbe, will get a decent Hakko soldering station, and understand general basics of electrical components and code when it comes to amperage/awg/voltage.
Does this sound doable?
Which Arduino would best fit the project? I will of course have this in a control panel in the garage.
How will a proximity sensor park your car perfectly? It is still up to the nut behind the wheel to make that happen.
At random times of day? You'll just wait for it to open to leave/enter?
  1. Verify Garage Door is Open/Close via a relay/light or better yet, through a web browser via the wifi or ethernet capability.
Piece of cake.
  1. I would like to have a set of LED's or Lights that would depict me to continue pulling forward and left or right depending on the cars orientation. I am guessing I would need some sensor that could measure the distance based on sonar/radar detection. I would like for it to be where I could use any car in the parking lot as long as I clear the garage door sensors so the garage door can close without obstruction.
A simple IR sensor at the garage door that turned a light on or off when the beam was unbroken could tell you that, for a specific car. Doing so for any kind of car requires a lot more lights/receivers.
Be sure to send us the URL so we can open and close your garage door at random times.
  1. Run the system off a clock
Probably easier to use a battery.
All easy enough to do, given the right external hardware, such as a real time clock.
Any of them is capable. Adding a shield to some models is easier than other.
