When I start this program and open the serial monitor I usually get a bit of garbage message which includes print statements that are part of my code. This usually only happens at the beginning but it is a little annoying that I can not figure this out.
// A derivation of a code I learned from Jack Purdum. One of the best instructors of Arduino C I have encountered.
#include <stdio.h>
#define pause 5000
#define readingPause 8000
int number = 5; // Define and declare an int variable
int *ptrNumber = NULL; // Define and declare an int pointer
void setup () {
void loop(){
Serial.println ("We have defined an int variable called number. It has an lvalue address and an rvalue which is what is held at that address.");
delay(readingPause);
Serial.println ("We have also defined a int pointer called ptrNumber which has a 2byte address and an rvalue which is meant to hold a variables lvalue address.");
delay (readingPause);
Serial.println ("We have set the rvalue to null in order to avoid junk data.");
delay(pause);
Serial.println ("Here are the results.");
delay(pause);
Serial.print("The lvalue for ptrNumber is ");
Serial.println((long)&ptrNumber,DEC);// The long is there to tell the compiler the data type we wish to use for the ptrNumber address, DEC instructs the reporting in base 10.
delay(pause);
Serial.print("The lvalue for number is ");
Serial.println ((long)&number,DEC);
delay(pause);
Serial.print("The rvalue for our pointer is ");
Serial.println((long)ptrNumber,DEC);
delay(pause);
Serial.print("The rvalue for number is ");
Serial.println (number);
delay(8000);
ptrNumber = &number;// Point the pointer at the lvalue of 'number'. This should make the pointer r value 'number's lvalue
Now whend we querry the processor as to the lvalue of number and the rvalue of ptrNumber we should get the same thing.
Serial.println ("Now we point the pointer at number using the address operator &.");
Serial.println ("The code looks like ptrNumber = &number ");
delay(pause);
Serial.println ("Here are the results:");
delay (pause);
delay(pause);
delay(pause);
Serial.print("The rvalue for our pointer is now ");
delay(pause);
Serial.print("The rvalue for number is still ");
delay(pause);
Serial.println("As you can see the rvalue for the pointer is the same as the lvalue of the pointers target. This is the result of pointing the pointer.");
/* Now we will use the indirection operator to allow the pointer to take control of the r value held at numbers address*/
Serial.println ("Now we use the indirection operator to allow our pointer to take control of the r value held at numbers address.");
Serial.println ("We will instruct the pointer to change the rvalue of number from 5 to 10 using the indirection operator");
Serial.println ("The code looks like: *ptrNumber = 10 ");
delay(pause);
Serial.println ("Here are the results: ");
*ptrNumber = 10;
delay(pause);
delay(pause);
delay(pause);
Serial.print("The rvalue for our pointer is still ");
delay(pause);
Serial.print("The rvalue for number is now ");
delay(pause);
Serial.println ("In this example we defined and declared a int variable. We then defined a pointer and set its rvalue to null.");
Serial.println ("Next we pointed the pointer using the address operator &. This placed the target variables lvalue in the pointers rvalue.");
Serial.println ("This ultimately gives the pointer control over the r value held at the variables address.");
Serial.println ("Finally we gave the pointer the power to change the r value of the variable by using the indirection operator *.");
Serial.println ("Most importantly, one must remember that all this is possible because the pointer had the variables address, which is held in the pointers rvalue.");
