Garbage on Serial after first character
I'm using this code on an ATMEGA168PA@3.3V 8Mhz external cristal:
  int i = 0;
  int rx = 0;
  delay(100);
  int r = Serial.available();
  if (r > 0)
      while (i < r)
          rx = Serial.read();
          Serial.println((int) rx);
          i++;
The ASCII code of the first character is correct, ex:
A
<65
For two character it's mostly garbage:
AA
<65
<200
AA
<65
65
And for more it's always garbage, but the first character is always correct.
ALOA
<65
<192
<210
<187
<255
Everything was working fine on a ATTINY85 with serial software.
I see "3.3V" and "8MHz" and "115200". There is something going on with those numbers.
With 8MHz you get slightly different baudrates due to the calculation. I think 38400 baudrate was the magical number that was best.
I have seen a table with the differences between 8MHz and 16MHz baudrates, but I can't find it right now.
The 3.3V might result in a weaker signal.
2 questions:
How is everything connected? (USB other?)
Have you tried it with lower baud rates? starting with 9600..
Yeah, according to this: http://www.wormfood.net, almost 8% of errors explains things.
It is connected to a serial bluetooth module (RN41), I tried with 250Kb speed but the BT modules can't handle it.
38K4 is, actually, the magic number.
Many thanks.
Thanks for finding that. This is the full link : WormFood's AVR Baud Rate Calculator Ver. 2.1.1
