garbage serial read from hc-05 on android
I am trying to read serial data from an Arduino bluetooth module.I am testing a simple receive loop, but I seem to get garbage data. My arduino code is
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(6, 7); // RX | TX
String my_string;
  BTSerial.begin(9600);
   while (BTSerial.available())
    char c = BTSerial.read();
    my_string += c;
    delay(2);
   BTSerial.write("shot\r\n");
My handler on Android is:
    class serial_handler extends Handler {
    public void handleMessage(android.os.Message msg) {
        switch (msg.what) {
            case RECIEVE_MESSAGE: // if receive massage
                byte[] readBuf = (byte[]) msg.obj;
                String strIncom = new String(readBuf, 0, msg.arg1); // create string from bytes array
                sb.append(strIncom); // append string
                int endOfLineIndex = sb.indexOf("\r\n"); // determine the end-of-line
                if (endOfLineIndex > 0) { // if end-of-line,
                    String sbprint = sb.substring(0, endOfLineIndex); // extract string
                    sb.delete(0, sb.length()); // and clear
                    Log.d("OP", "CHAR:"+ sbprint);
                Log.d("OP", "...String:"+ sb.toString() +  "Byte:" + msg.arg1 + "...");
But I see garbage received on the serial input on Android:
...String:�cn�p`t�ch`d�
    sCh�cH�p`dshoD����cH�ptshod1�
    s
    Chc�s�rByte:1...
I am not sure where is additonal garbage serial data is coming from. Is my arduino loop set up right?
I can see the desired characters for a bit and then it goes downhill.
Has anyone faced such issues before?
D/OP: CHAR:s
D/OP: CHAR:hot
D/OP: CHAR:s
D/OP: CHAR:hot
D/OP: CHAR:s
D/OP: CHAR:hot
D/OP: CHAR:s
D/OP: CHAR:hot
D/OP: CHAR:`
D/OP: CHAR:�
D/OP: CHAR:
D/OP: CHAR:��
D/OP: CHAR:r
D/OP: CHAR:
D/OP: CHAR:�
D/OP: CHAR:�
D/OP: CHAR:�
D/OP: CHAR:�
D/OP: CHAR:��
D/OP: CHAR:�
D/OP: CHAR:��
D/OP: CHAR:`����
