Garbage values from a timer - arduino mega
Hi everyone!
I'm working on a project which includes three ultrasonic sensors. I am using arduino Mega.
I connected all three ECO pins through an OR gate in order to mesure the ECHO pulse width with INT2 external interrupt. With OC0, OC1 and OC2, I am generating a 10us TRIG pulse, that way I know whos sensor pulse I measuring. I use TIMER5 as my counter to measure the pulse ON time.
It works greats for me with the sensor triggered by OC1B. when I try to use the two other sensors I get garbage values on my serial monitor:
(�␘���@aXa�␂��@aXa␘H␂@@@aXaH␂��@a�aL).
Even in case it is a hardware problem, I should read some unreliable value. But since it is a garbage values I guess it has something to do with my code.
I will mention the the calculation are excecuted and done by the ISR(INT2_vect). SInce that I suspect two things:
  1. I did not set up the timers correctly.
  2. Using Serial.println() is trying to use the same timers I use.
  3. I use wrong type of data for my numberws.
Here is my code and functions (pay attention to the function trigState() on line 71 in the main() function):
#include <Arduino.h>
#define   DISABLE         0
#define   ENABLE          1
// Define ultrasonic trigger pins
#define   F_TRIG_PIN      12 // Ultrasoniv trigger pin, OCR1B
#define   L_TRIG_PIN      9  // Ultrasoniv trigger pin, OCR2B
#define   R_TRIG_PIN      4  // Ultrasoniv trigger pin, OCR0B
// Define motor control pins
#define   RIGHT_FORWARD   2
#define   RIGHT_BACKWARD  3
#define   LEFT_FORWARD    6
#define   LEFT_BACKWARD   7
// Define motor speeds
#define   DRIVE           0//0xAF    // Full Speed
#define   STOP            0x00
#define   N               65536 // Maximum value for a 16-bit counter to count
#define   D_MIN           20 // Minimum front distance to stop [cm]
#define   D_REV           10  // Front distance to drive backwards [cm]
#define   TIMR1_PS        8 // IF CHAMGING - CHAMGE ALSO BITS IN TCCR1B REGISTER
// Declare functions
void trigState(bool leftState, bool frontState, bool rightState); // Choose ultrasonic direction
void setupFrontUltrasonic();
void setupLeftUltrasonic();
void setupRightUltrasonic();
void enableEcho(); // Enable echo pulse capturing and measurement
void setupMotors(); // Setup motors PWM parameters
void setupCounter();
// Parameters for ulstasonic interrupts
volatile int            OVFcounter = 0;
volatile unsigned int   N1 = 0, N2 = 0, dN = 0;
volatile unsigned int   dT = 0, D = 0;
volatile bool           rising = 1;
  // Define pins data direction
  pinMode(RIGHT_FORWARD, OUTPUT);
  pinMode(RIGHT_BACKWARD, OUTPUT);
  pinMode(LEFT_FORWARD, OUTPUT);
  pinMode(LEFT_BACKWARD, OUTPUT);
  pinMode(F_TRIG_PIN, OUTPUT);
  pinMode(L_TRIG_PIN, OUTPUT);
  pinMode(R_TRIG_PIN, OUTPUT);
  pinMode(13, OUTPUT);
  // Set initial conditions
  digitalWrite(F_TRIG_PIN, LOW);
  digitalWrite(L_TRIG_PIN, LOW);
  digitalWrite(R_TRIG_PIN, LOW);
  digitalWrite(13, LOW);
  // Initialize system
  trigState(DISABLE, ENABLE, DISABLE);
  enableEcho();
  setupMotors();
  setupCounter();
  sei(); // Enable all interrupts
  Serial.println(D);
  if(D <= D_MIN){
    if(D<D_REV){
      OCR3B = DRIVE;   // RIGHT_BACKWARD speed (MAX is 0xFF)
      OCR3C = STOP;   // RIGHT_FORWARD speed (MAX is 0xFF)
      OCR4A = STOP;   // LEFT_FORWARD speed (MAX is 0xFF)
      OCR4B = DRIVE;   // LEFT_BACKWARD speed (MAX is 0xFF)
    } else{
      OCR3B = STOP;   // RIGHT_BACKWARD speed (MAX is 0xFF)
      OCR4B = STOP;   // LEFT_BACKWARD speed (MAX is 0xFF)
    OCR3C = DRIVE;   // RIGHT_FORWARD speed (MAX is 0xFF)
    OCR4A = DRIVE;   // LEFT_FORWARD speed (MAX is 0xFF)
// End of ultrasonic trigger pulse. Enable external interrupt for echo pulse width  measurement
ISR(TIMER1_COMPB_vect){
  EIMSK |= 1<<INT2;
  TCNT5 = 0;
// External interrupt for echo pulse width  measurement
ISR(INT2_vect){
  digitalWrite(13, 0);
  if(rising){
    N1 = TCNT5;
    //Flip state to interrupt on rising edge
    EICRA &= 0<<ISC10;
    rising = 0;
  } else{
    N2 = TCNT5;
    //Flip state to interrupt on falling edge
    EICRA |= 1<<ISC20;
    rising = 1;
    // Calculation to span distance values (D) accross timer counts values (N):
    // Pulse width is: dT = dN*TIMR1_PS/FREQ
    // dX = v*dT  -->  D = dT*C/2  -->  D = dN*TIMR1_PS*C/(FREQ*2)
    // Hence: D=0 | dN=0 and D=557[cm] | dN=N=65536
    dN = N2-N1;
    D = 557*(double)dN/N; // Results in [cm]
ISR(TIMER3_COMPB_vect){}  // RIGHT_BACKWARD
ISR(TIMER3_COMPC_vect){}  // RIGHT_FORWARD
ISR(TIMER4_COMPA_vect){}  // LEFT_FORWARD
ISR(TIMER4_COMPB_vect){}  // LEFT_BACKWARD
void setupFrontUltrasonic(){
    TCCR1A = 0;
    TCCR1B = 0;
    TCCR1C = 0;
    TIMSK1 = 0;
    // Fast mode PWM
    TCCR1A |= 1<<WGM10;
    TCCR1A |= 1<<WGM11;
    TCCR1B |= 1<<WGM12;
    TCCR1B |= 1<<WGM13;
    TCCR1A |= 1<<COM1B1; // OC1B output fall on compare match -> Datasheets Pg. 154
    OCR1A = 0xFFFF; // MAX value for for counter 1B
    OCR1B = 20; // Number of counts to generate 10 microseconds p
    TIMSK1 |= 1<<OCIE1B; // Enable TIMER1_COMPB_vect ISR
    return;
void setupLeftUltrasonic(){
    TCCR2A = 0;
    TCCR2B = 0;
    TIMSK2 = 0;
    // Fast mode PWM
    TCCR2A |= 1<<WGM20;
    TCCR2A |= 1<<WGM20;
    TCCR2B |= 1<<WGM22;
    TCCR2A |= 1<<COM2B1; // OC1B output fall on compare match -> Datasheets Pg. 154
    OCR2A = 0xFF; // MAX value for for counter 1B
    OCR2B = 20; // Number of counts to generate 10 microseconds pulse
    TIMSK2 |= 1<<OCIE2B; // Enable TIMER2_COMPB_vect ISR
    return;
void setupRightUltrasonic(){
    TCCR0A = 0;
    TCCR0B = 0;
    TIMSK0 = 0;
    // Fast mode PWM
    TCCR0A |= 1<<WGM00;
    TCCR0A |= 1<<WGM01;
    TCCR0B |= 1<<WGM02;
    TCCR0A |= 1<<COM0B1; // OC1B output fall on compare match -> Datasheets Pg. 154
    OCR0A = 0xFF; // MAX value for for counter 1B
    OCR0B = 20; // Number of counts to generate 10 microseconds p
    TIMSK0 |= 1<<OCIE0B; // Enable TIMER1_COMPB_vect ISR
    return;
void trigState(bool leftState, bool frontState, bool rightState){
    if(leftState) // ENABLE
        TCCR2B |= 1<<CS21;
    else //DISABLE
        TCCR2B &= 0b11111000;
    if(frontState) // ENABLE
        TCCR1B |= 1<<CS11;
    else //DISABLE
        TCCR1B &= 0b11111000;
    if(rightState) // ENABLE
        TCCR0B |= 1<<CS01;
    else //DISABLE
        TCCR0B &= 0b11111000;
    return;
void enableEcho(){
    EICRA = 0;
    EIMSK = 0;
    // Datasheets Pg. 110
    EICRA |= 1<<ISC20; // | 1<<ISC21;  // Select edge type to interrupt
    EICRA |= 1<<ISC21;
    EIMSK |= 1<<INT2;           // Enable external interrupt
    return;
void setupMotors(){
    // Setting right motor PWM
    // Drive D2 & D3 HIGH when TCNT3 < OCR3x while up-counting
    // Drive D2 & D3 LOW when TCNT3 > OCR3x while up-counting
    //>>>>>>>> DATASHEETS PG. 154
    // Set outputs to work in Fast PWM mode
    // >>>>>>>> DATASHEETS PG. 145 <<<<<<<<
    // Set timers to count without prescalar
    // >>>>>>>> DATASHEETS PG. 156 <<<<<<<<
    TCCR3A = 0b00101001;    // Pin toggling mode (HIGH to LOW)
    TCCR3B |= 0b00001001;   // Prescalar and Fast PWM
    TCCR3B &= 0b11111001;
    TIMSK3 |= 0b00001100;   // Enable On-Compare-Interrupt B&C
    OCR3B = 0;           // RIGHT_BACKWARD speed (MAX is 0xFF)
    OCR3C = 0;           // RIGHT_FORWARD speed (MAX is 0xFF)
    //  Drive D6 & D7 HIGH when TCNT4 < OCR4x while up-counting
    // Drive D6 & D7 LOW when TCNT4 > OCRx while up-counting
    TCCR4A = 0b10100001;    // Pin toggling mode (HIGH to LOW)
    TCCR4B |= 0b00001001;   // Prescalar and Fast PWM
    TCCR4B &= 0b11111001;
    TIMSK4 |= 0b00000110;   // Enable On-Compare-Interrupt B&C
    OCR4A = 0;           // LEFT_FORWARD speed (MAX is 0xFF)
    OCR4B = 0;           // LEFT_BACKWARD speed (MAX is 0xFF)
void setupCounter(){
    TCCR5A = 0;
    TCCR5B = 0;
    TCCR5C = 0;
    TCCR5B = 1<<CS51;   // No prescalar for maximum accuracy
    return;
The serial output looks like (1) baud mismatch or (2) needs a reset (the ESP32 will send out stuff like that until you mash the "reset" button).
3 possible errors:
  • Is the baud rate correct? It should be 9600 on your Serial Monitor.
  • Is there something interfacing with the timing on Serial.println();?
  • Is the Arduino using a reliable power source?
I initially thought that the intention here is to flip or toggle a single bit, which can be done with xor:
EICRA ^= 1<<ISC10;
EICRA ^= 1<<ISC20;
However, maybe the intention in this statement was to 'unset' a bit:
EICRA &= 0<<ISC10;
That isn't going to work. 0<<ISC10 is still = 0! There are no set bits to shift! This will simply clear the whole register, setting all its bits to zero.
To unset a bit you would do:
EICRA &= ~(1<<ISC10);
This creates the value of 1 shifted by ISC10, then inverts it to create a 'mask' with all ones but the bit at ISC10=0, then that is ANDed that with he value of EICRA. The target bit is ANDed with 0 will be unset. The other bits are ANDed with 1 and retain their original setting.
However, I was also curious as to why in one case the code is using the value of ISC20 whereas in the other case it used ISC10? Aren't both cases related to INT2? Therefore, shouldn't both cases use the value of ISC20? From the Atmel Mega 2560 datasheet, page 111, it would also appear that interrupting on the rising edge requires the bit to be set, but unset on the falling, so the logic of the 'if (rising) {' statement may be reversed.
EDIT: Sorry for bothering all of you.. I forgot adding an ISR for TIMER0 andTIMER2, which turns INT2 to LOW. Now everything works just fine. Still don't understand why I get garbage values instead of numbers.
Hi, thank you for the reply!
  1. I dont think it's a problem with the monitor baudrate since the exact same program works with the same setting right after I enabls the front ultrasonic sensor (as long as the IDE does not change it by itself).
  2. I order to negate this assumption I disabled any serial interface, and replaced the loop() section:
  //Serial.println(D);
  if(D <= D_MIN)
    digitalWrite(13,0);
    digitalWrite(13, 1);
And again - the desired command works just with the front ultrasonic.
  1. Yes, I am using fully charged Li-Ion battery.
A few thigs that might help you help me find the solution:
  1. I tried printing the string "Ok". It worked with the front ultrasonic enabled, but not with the other ones. Hence I assumed the serial port has nothing to do with TIMER5 used inside the ISR, but just with TIMER0 and TIMER2 associated with the left and right ultrasonic sensors.
  2. I disabled ALL ultrasonic sensors, and printing to the serial monitor worked fine. Hence setting NO CLOCK SOUCE for TIMER1 (front ultrasonic in trigState) does not affect the serial port.
  3. I tried using flag:
    if(flag){
        cli();
       Serial.println(D);
       flag =0;
       sei();
and setting the flag back to zero at the end of the pulse measurement (else statement inside the ISR).
A few points to pay attention to are:
  1. TIMER0 and TIMER2 associated with the left and right ultrasonic sensors have 8 bits counters (while TIMER1 counters are 16 bits). That means I triggers the sensors again before ECHO pulse ends. Though by looking at the oscilloscope it does not affect the ECHO pulse. Even if it does, I expect getting just unreliable values. No?
  2. I creates left and right ultrasonic code blocks and functions by copying and pasting a lot of the front ultrasonic code. I was looking for mistakes but I could not find one..
I hope it might help us get to the solusion..
