Thank you for taking the time to reply, I've edited the photos. Forgive my ignorance, but if it's not too much trouble could you show me what you mean so I know how to change the code? I'm having a bit of trouble figuring out how to do it.
Is it this part of the code I need to change:
void calibrate()
//This function calibrates the pH stamp with the current temperature read from the DS18B20 temp sensor
pHserial.print(getTemp()); //pritn temp in degrees C to Ph Sensor
pHserial.write("\r"); //carrage return
clearLCD();
selectLineOne();//move up to the first line of the LCD
goTo(4);//Move in 4 spaces on the second line to center text
Serial.print("Complete");
selectLineTwo();//move down to the second line of the LCD
goTo(19);//move in to position 19 to center text
Serial.print("Temp=");//print the temperture that was used to calibrate to the LCD
Serial.print(convertTemp());
Serial.print("F");
