Hello,
i got my hands on the pro mini with FTDI breakout. Among first things i tried was :
delay(10000);
Serial.println("test");
which, to my surprise was producing a garbled text on the monitor. ( I tried in PlatformIO and Arduino 1.6.5 - neither worked).
The Baud in monitors was set to 9600.
To my surprise the BAUD in the monitor that worked was 19600. See attached.
My question is why ?
I have nothing connected to Mini. it sits on the wooden desk with ftdi and usb cable - so not a grounding issue.
Appreciate.
AZZ:
Hello,
delay(10000);
Appreciate.
Your Pro Mini will be either an 8MHz or 16MHz version - you didn't say which - (one is twice as fast as the other).
Your baud rates 9600 / 19200 are out by a factor of 2.
Does that help you isolate the problem ?
6v6gt:
My bad. It is 3.3V 328, so it is (should be) 8Mhz.
