I try to activate a garden-waterpump for a fountain in short intervals, i.e. 10sec ON, 50sec OFF. The code is very simple, and it works on my desktop with a lamp connected - as I want it to.
When installing it in my gardenhouse (dry environment ) it stops working - sometimes right away -sometimes after a while.
I use a standard water pump 220V from "Bauhaus". I tried to connect it through a double relay (for both N and P), and have grounded it as prescribed.
The relay is powered by an external power supply, so there shouldn´t be any galvanic connection between the 220V circuit and the Arduino. (I used a double identical setup - one with an Arduino Nano, the other with an Arduino Uno). Exactly same result...
I guess there must be some kind of an interference from the switching in the relay with the Arduino... Any ideas???
#include <Wire.h>
int relayPin = 6; //pin 6 går til LED som test eller senere til relais vor 220V
int startPin=7;
int stopPin=8;
//indstilling af antal cykler per time - og vandingstid per gang i sec.
int antalCyklerT =600; // number of cycles per hour ... her gives antal perioder som der vandes her time - fra 1-30 per time
int vandingTidSec = 1; //on-time in seconds ... her indstilles hvor mange sekunder pumpen skal køre ad gangen.
int vandingPauseSec = ((3600 / antalCyklerT) - vandingTidSec);//break between ON times (calculated value)
int n=1;
void setup () {
delay(3000);
pinMode(relayPin, OUTPUT);
pinMode(startPin, OUTPUT);
pinMode(stopPin, OUTPUT);
Wire.begin();
Serial.print("Number of cycles: " );
Serial.print(antalCyklerT);
Serial.print(" - per hour");
Serial.print("ON time in seconds: " );
Serial.println(vandingTidSec);
Serial.print("OFF time in secondes: " );
Serial.println(vandingPauseSec);
digitalWrite(startPin, LOW);
digitalWrite(stopPin, HIGH);
digitalWrite(relayPin, HIGH);
n=1;
Serial.print("N:=");
Serial.println(n);
void loop () {
while (n>=1){ //the loop is running indefinitly - for testing purpose
digitalWrite(relayPin, LOW);
digitalWrite(startPin, HIGH);
digitalWrite(stopPin, LOW);
delay (vandingTidSec * 1000); //delay for antal sekunder
delay(vandingPauseSec * 1000);
n=n+1;
Serial.println(n);
