Hello everyone, im new here. Just wanna ask if someone work with T6615 gas sensor already?
Put your sensor id in the forum search box and search. Besides seeing your post, there is another that references the same device.
The Product documentation for the sensor seems to me to be comprehensive and fairly digestible!
in the UART communication protocol document I found, on page 8, it actually lists out the request bytes to send and how to interpret the response.
for example, to get the gas_ppm, something like this maybe:
(Compiles, Not tested!)
uint8_t req_GasPPM[5] = {0xFF, 0xFE, 0x02, 0x02, 0x03};
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial1.begin(19200); //Serial1 (MEGA) is connected to T6615 gas sensor
Serial.print("T6615 gas sensor Example");
uint16_t i = 0, gas_ppm = 0;
Serial.print("Requesting GAS PPM");
//send request to CO2 sensor
for (int j = 0; j < 5; ++j) {
Serial1.write(req_GasPPM[j]);
delay(1000); //arbitrary delay
//wait for complete response to be received
while (Serial1.available() < 5);
while (Serial1.available()) {
++i;
uint8_t b = Serial1.read();
Serial.print(b, HEX);
Serial.print(" ");
if (i == 4) {
gas_ppm = b; //MSByte received
else if (i == 5) {
gas_ppm = (gas_ppm << 8) | b; //LSByte received
if (i > 0) {
Serial.print("Gas ppm:");
Serial.println(gas_ppm);
hope that helps...
