So I am stuck with my project. I am creating gas sensos that transfers data to thingspeak. I am usig ESP - 01, ARDUINO NANO, PIEZO BUZZER, MQ2 GAS SENSOR, LED. So my only problems is that my esp-01 can't connect to WIFI, and I need help to solve this problem. Posting code below
#include <SoftwareSerial.h>
SoftwareSerial espSerial = SoftwareSerial(2,3); // arduino RX pin=2 arduino TX pin=3 connect the arduino RX pin to esp8266 module TX pin - connect the arduino TX pin to esp8266 module RX pin
float sensor=A0;
float gas_value;
String apiKey = "IUW8M8C5PQDFX7LA"; // replace with your channel's thingspeak WRITE API key
String ssid="calculator"; // Wifi network SSID
String password ="calculator"; // Wifi network password
boolean DEBUG=true;
#define VOLTAGE_MAX 5.0
#define VOLTAGE_MAXCOUNTS 1023.0
//======================================================================== showResponse
void showResponse(int waitTime){
long t=millis();
char c;
while (t+waitTime>millis()){
if (espSerial.available()){
c=espSerial.read();
if (DEBUG) Serial.print(c);
//=======================connection to thinkspeak.com=================================================
boolean thingSpeakWrite(float value1){
String cmd = "AT+CIPSTART=\"TCP\",\""; // TCP connection
cmd += "184.106.153.149"; // api.thingspeak.com
cmd += "\",80";
espSerial.println(cmd);
if (DEBUG) Serial.println(cmd);
if(espSerial.find("Error")){
if (DEBUG) Serial.println("AT+CIPSTART error");
return false;
String getStr = "GET /update?api_key="; // prepare GET string
getStr += apiKey;
getStr +="&field1=";
getStr += String(value1);
//getStr +="&field2=";
//getStr += String(value2);
getStr += "\r\n";
// send data length
cmd = "AT+CIPSEND=";
cmd += String(getStr.length());
delay(100);
if(espSerial.find(">")){
espSerial.print(getStr);
if (DEBUG) Serial.print(getStr);
else{
espSerial.println("AT+CIPCLOSE");
// alert user
if (DEBUG) Serial.println("AT+CIPCLOSE");
return false;
return true;
//================================================================================ setup
DEBUG=true; // enable debug serial
//----------my sensor code-----------
pinMode(LED_BUILTIN, OUTPUT);
pinMode(sensor,INPUT);
espSerial.begin(115200); // enable software serial
// Your esp8266 module's speed is probably at 115200.
// For this reason the first time set the speed to 115200 or to your esp8266 configured speed
// and upload. Then change to 9600 and upload again
//espSerial.println("AT+RST"); // Enable this line to reset the module;
//showResponse(1000);
//espSerial.println("AT+UART_CUR=9600,8,1,0,0"); // Enable this line to set esp8266 serial speed to 9600 bps
espSerial.println("AT+CWMODE=1"); // set esp8266 as client
showResponse(1000);
espSerial.println("AT+CWJAP=\""+ssid+"\",\""+password+"\""); // set your home router SSID and password
showResponse(5000);
if (DEBUG) Serial.println("Setup completed");
// ======================================================================= loop
//---------my gas sensor value reading-------------------
gas_value=analogRead(sensor);
Serial.println(gas_value);
delay(1); //delay in between reads for stability
if(gas_value>250){
// initialize digital pin LED_BUILTIN as an output.
digitalWrite(LED_BUILTIN, HIGH);
//delay(250);
// digitalWrite(LED_BUILTIN, LOW);
//delay(250);
float t = gas_value*(VOLTAGE_MAX / VOLTAGE_MAXCOUNTS); //convert gas value to voltages
if (isnan(t)) {
if (DEBUG) Serial.println("Failed to read from MQ2");
else{
if (DEBUG) Serial.println("Voltage="+String(t));
thingSpeakWrite(t); // Write values to thingspeak
// thingspeak needs 15 sec delay between updates, */
delay(20000);
else{
