I was thinking of implementing the idea to open the gates automatically (gates open 90 degrees) and I am not sure whether this idea is viable or is there a better alternative in choosing the parts?:
Basically there will be motor sitting in front of the gates (at the open position) and with the press of a button motor spins the slipper clutch which would then spin the winch spool (wheel drum) which would pull the rope attached to the gate.
So 12 V motor -> slipper clutch -> winch spool/wheel. With the slipper clutch in between I want to make sure that if the battery dies or something else goes wrong, the gates would not get stuck in between open/close position, so the person could manually close the gates. Or even while the gates are opening, I could manually close them (the clutch would disengage the motor).
Also I am not sure if this slipper clutch would be able to pull ~ 3 kg. to open the gates without slipping.
Slipper clutch and winch spool found on Ali:
Slipper clutch
Winch spool
Is this doable or should I choose a different approach to safely pull a rope? Thanks.
Thanks for any help.
