GBA help with how to program
int button1 = 2;  // Set a button to any pin
int button2 = 3;  // Set a button to any pin
int button3 = 4;  // Set a button to any pin
int button4 = 5;  // Set a button to any pin
int button5 = 6;  // Set a button to any pin
int button6 = 7;  // Set a button to any pin
int button7 = 8;  // Set a button to any pin
int button8 = 9;  // Set a button to any pin
int button9 = 10;  // Set a button to any pin
int button10 = 15;  // Set a button to any pin
  pinMode(button1, INPUT);  // Set the button as an input
  pinMode(button2, INPUT);  // Set the button as an input
  pinMode(button3, INPUT);  // Set the button as an input
  pinMode(button4, INPUT);  // Set the button as an input
  pinMode(button5, INPUT);  // Set the button as an input
  pinMode(button6, INPUT);  // Set the button as an input
  pinMode(button7, INPUT);  // Set the button as an input
  pinMode(button8, INPUT);  // Set the button as an input
  pinMode(button9, INPUT);  // Set the button as an input
  pinMode(button10, INPUT);  // Set the button as an input
  digitalWrite(button1, HIGH);  // Pull the button HIGH
  digitalWrite(button2, HIGH);  // Pull the button HIGH
  digitalWrite(button3, HIGH);  // Pull the button HIGH
  digitalWrite(button4, HIGH);  // Pull the button HIGH
  digitalWrite(button5, HIGH);  // Pull the button HIGH
  digitalWrite(button6, HIGH);  // Pull the button HIGH
  digitalWrite(button7, HIGH);  // Pull the button HIGH
  digitalWrite(button8, HIGH);  // Pull the button HIGH
  digitalWrite(button9, HIGH);  // Pull the button HIGH
  digitalWrite(button10, HIGH);  // Pull the button HIGH
   if (digitalRead(button1) == 0)  // if the button goes low
    Keyboard.write('z');  // send a 'z' to the computer via Keyboard HID
  if (digitalRead(button2) == 0)  // if the button goes low
  if (digitalRead(button3) == 0)  // if the button goes low
  if (digitalRead(button4) == 0)  // if the button goes low
  if (digitalRead(button5) == 0)  // if the button goes low
  if (digitalRead(button6) == 0)  // if the button goes low
  if (digitalRead(button7) == 0)  // if the button goes low
  if (digitalRead(button8) == 0)  // if the button goes low
  if (digitalRead(button9) == 0)  // if the button goes low
 if (digitalRead(button10) == 0)  // if the button goes low
Would this work ?? the z's will be changed to the letter I want to be used.
What my friend and I are trying to do is make a old game emulator and put it into a TI-84 SE calculator. We are going to be using the rhasberry pi with Debian to install our Emulators for GBA,GBC, SNES, GC, ATARI, and NES on. We need the Arduino to send button presses from a pcb board we are making to the rhasberry pi via USB.
