GBF( générateur de basse fréquence) with ARDUINO PWM problem frequency
Hey have a Good Day! :slight_smile: :slight_smile:
I am working on a project of a frequency probe and I need to create a GBF goes from ]0-10KHz]
I am using an Arduino Uno board to generate a PWM to get frequency.
I’am using Potentiometr to change the frequency on A0 pin of my ARDUINO baord .
I need help to fix my Program to provide at least from 1 HZ to 11khz frequency of pwm.
my out put is on pin 9.
this is my program:
#include "Arduino.h"
#define NECHANT 128
#define SHIFT_ACCUM 25
uint32_t icr;
uint32_t table_onde[NECHANT];
uint32_t accum1,accum2,accum3,increm;
uint16_t diviseur[6] = {0,1,8,64,256,1024};
void init_pwm_timer1(uint32_t period) {
    char clockBits;
    TCCR1A = 0;
    TCCR1A |= (1 << COM1A1); //Clear OC1A on compare match when upcounting, set OC1A on compare match when downcounting
    TCCR1A |= (1 << COM1B1);
#if defined(__AVR_ATmega2560__) || defined(__AVR_ATmega32U4__)
    TCCR1A |= (1 << COM1C1);
#endif
    TCCR1B = 1 << WGM13; // phase and frequency correct pwm mode, top = ICR1
    int d = 1;
    icr = (F_CPU/1000000*period/2);
    while ((icr>0xFFFF)&&(d<6)) { // choix du diviseur d'horloge
        d++;
        icr = (F_CPU/1000000*period/2/diviseur[d]);
   clockBits = d;
   ICR1 = icr; // valeur maximale du compteur
   TIMSK1 = 1 << TOIE1; // overflow interrupt enable
   sei(); // activation des interruptions
   TCNT1 = 0; // mise à zéro du compteur
   TCCR1B |= clockBits; // déclenchement du compteur
ISR(TIMER1_OVF_vect) { // Timer 1 Overflow interrupt
  accum1 += increm;
  accum2 += increm;
  accum3 += increm;
  OCR1C = table_onde[accum3 >> SHIFT_ACCUM];
#endif
  OCR1A = table_onde[accum1 >> SHIFT_ACCUM];
  OCR1B = table_onde[accum2 >> SHIFT_ACCUM];
void set_sinus_table(float amp) {
  int i;
  float dt = 2*3.1415926/NECHANT;
  for(i=0; i<NECHANT; i++) {
    table_onde = icr*0.5*(1.0+amp*sin(i*dt));
     int p;
    pinMode(9,OUTPUT);
    pinMode(A0,INPUT);
Serial.begin(19200);
    p=analogRead(A0);
p=map(p,0,1023,0,255);
Serial.println(p);
analogWrite(9,p);
    uint32_t period_pwm = 1.5*p; // en microsecondes
    uint32_t frequence = 40*p; // en Hz
    accum1 = 0;
    accum2 = ((uint32_t)(NECHANT * 0.25)) << SHIFT_ACCUM;
    accum3 = 0;
    increm = (uint32_t) (((float)(0xFFFFFFFF))*((float)(frequence)*1e-6*(float)(period_pwm))); // incrément de l'accumulateur de phase
    init_pwm_timer1(period_pwm);
    set_sinus_table(1.0);
Did you write that code? What do you expect fromanalogWrite(9,p);
Thank you For your reply
Found the code on internet but i changed it
yes you are right i think that i don't need that line of code in my case
this is the link :
http://www.f-legrand.fr/scidoc/docimg/sciphys/arduino/ondepwm/ondepwm.html
