Can I start a print with a Z = 20mm?
I use Slic3r and I want to print a piece on another piece that i printed before (h = 20mm), then i want that the second print start with a Z = 80mm.
I believe you can use the G1 command like this:
G1 Z0.300 F11700.000
where the number after Z is the height in millimeters the Z axis has to travel.
Please beware that this should work, but I haven't tested it.
dp_1
