Hi everyone! I'm trying to make a gear hobbing machine with arduino, I wrote a code that seems to work, but on the machine it just can't make any gear. I think the synchronization between the two spindles are not correct. I think my code that has the problem. Anyone has any ideas how I can fix it?
Sorry for the late reply. I started with a manual machine, and I tried to automate it. So the problem I'm having is that when I start the hobbing it seems good but after a few rotations of the secondary spindle (the spindle that is driven by the stepper), it starts to mess up the gear. If I left it to run on one position it just completly shears off the gear. And I'm using a quadrature encoder, can you help me how to decode all of the pulses?
Please give more detail about the manual gear hobbing machine. Can you point to the model you started with? Can you point to instructions on how to use it manually?
You have an encoder and a stepper. How are they attached to your manual gear hobbling machine?
Maybe check on CNCZone to see if someone has automated a hobbing machine. In a sense it's a similar problem to an electronic leadscrew and I know they've done lots of that.
